Bluetooth Options For 2008 Silverado
Or do what we've been talking about here, which is as much of a "factory" upgrade as there is, so far.
Joe
Yes, it works great and is about the easiest upgrade I've done for my truck.
  • Replies 735
Joe
Except you have to have steering wheel controls, and find a VCIM since GM won't sell you one :thumbs:
I see four part numbers for Onstar VCIM with Bluetooth. I know I have seen three mentioned in this thread. Any idea of what functionality would be added or lost with each part number. The part numbers are:
25984444
25984445
20783878
20783877
I am not sure about 25984445 or 20783878. I can vouch for 25984444 and 20783877 both work. I did and experiment this weekend. I originally purchased 20783877 and installed in my truck. I needed another one for My G8 and found 25984444 on ebay, and decided to give it a try. Instead of just putting it in the G8, I figured I would pull the 20783877 out and install the 25984444. And it worked. I had to re-pair my phone and re-add my stored name tags. I took some pics and as far as I can tell, there is no external difference. I would open them up, but with my luck, I'm sure they would die. Here are the pics:
Side By Side
Side By Side Back
Side By Side Back 2
Antenna came apart when I removed it, cover just came off (may want to take yours off by taking the side panel off and reaching around the back before you remove it if you ever have to.
I got interested in this option when this thread first started. I was disappointed when I found GM put restrictions on the purchase of the VCIM. I did a search on Ebay for 20783877 and found nothing. I did save the e=search and about 2 weeks ago got a email saying it found a 20783877 for sale. It was a buy it now for $139. for a 33,000 mile box out of an Enclave. I took a chance and bought the box. I ordered the antenna from my dealer and waited for the parts. It all came together today. The hardest part was figuring out how to remove the lower dash plastic cover. Once the cover is off the box is right there in a plastic spring loaded retainer. I disconnected the battery and swapped out the box. I then reinstalled the dash panels and reconnected the battery. I got 2 green lights on my rear view Onstar mirror and everything including BLUETOOTH works. Thanks to all the contributors who made this possible.
Magnaflo cat back dual exhaust goes on Friday then..................................................A Blackbear Tune Rick
Rick,
Do you have the steering controls and/or the updated Onstar mirror? I don't have either. I'm wondering if I buy a used but activated VCIM, antenna and microphone if that's all I need.
Thanks.
Rick,
Thanks.
I have the steering wheel controls however I don't know anything about an updated mirror. My mirror is the optional auto dimming one. Rick
WOW, I just read through all 19 pages and I still have a few questions.
I currently have a 2009 GMC Sierra SLE w/active OnStar, active XM radio. However the truck did NOT come with BlueTooth option or steering wheel radio controls.
Is GM PART # 25851951 the new upgraded BlueTooth/Radio steering wheel controls and is it a simple plug and play upgrade (remember my truck did NOT come with steering wheel controls)?
What else do I have to buy to install factory BlueTooth in my truck (remember this is a 2009 Sierra SLE)?
I want to be able to use my OnStar since I have an active 12 month account.
Thanks for any help.
Can some one PLEASE tell me if GM PART # 25984445 is any good ,i know my auto wrecker has 4 of them ,Thanks for help
Which auto wrecker?......if its good I want one
See in the photos above the VCIMs have a sticker on them with serial numbers and the sticker also has a BlueTooth logo. If yours has the logo I would say its a good bet it works
So if I read this right, there are four parts that we could swap out our VCIM (2009 silverado in my case): 25984444, 20783877, 25984445, 20783878. What is interesting is that you can buy parts 25984445 and 20783878 from GM Parts direct for around $200 while the other two are restricted. Anyone know why they havent restricted those? What exactly is the difference, did they just come out of different cars?
Ernie
Ernie
I think you may find that some numbers have superceded others and are no longer valid.
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
