Bluetooth Options For 2008 Silverado
Plugs into VCIM.....
So I am assuming that it is pretty small.
It's about 1"x1" and has the ant. plug attached it's really small and takes up no space or additional work. Just clip it on and your done!
JTS
  • Replies 735
JTS
Anyone find a VCIM.....nothin on EBay right now
Read every post in this thread, and have a few questions....mainly about Bluestar / bluetooth.
Has anyone tried this with an iPhone....GM site says its compatible.????
In bluetooth mode....does the it utilize all FOUR speakers....or just the front two ??
With this setup....has anyone tried streaming audio from their phone (any phone)....streaming stereo A2DP audio??
It would help me, especially before i dive into this treasure hunt with the rest of you guys!!! Go LSU !!!
Got my eBay VCIM ($100 and included the bluetooth antenna) today...oh my gosh...IT WORKS AND IT WORKS GREAT. Not to rub it in but if you can get your hands on a new or used one, do it. Plug and play and it uses the factory installed mic - 20 minutes to install and no dealer programming. Onstar works too - I'm not sure if its because I have a used one (4 miles on the wrecked Enclave) or if it will stop working in the future. I also have the two green lights on the rear view mirror.
Special thanks to 07crewsierra for breaking the news about being able to use a VCIM out of a 2009 in a 2008.
I just picked up a vcim for my trailblazer,waiting on the antenna to see if it is plug and play.Im in Ontario Canada
Ya right....buy it in Canada at 4X the cost.
Example.....Steering wheel switch assembly USA retail = $26
Canadian retail = $74....I got it for employee pricing $45can
Im waiting for Ebay......
Communication Interface Module Replacement (with RPO SLT)
Callout
Component Name
  1.
Preliminary Procedure
  1. <LI type=1>Remove the instrument panel accessory trim plate. Refer to
Instrument Panel Accessory Trim Plate Replacement. <LI type=1>Remove the HVAC control module. Refer to HVAC Control Module Replacement or HVAC Control Module Replacement.
Remove the radio. Refer to Radio Replacement.
Tip
• Push outward on the 2 tabs to release the communication interface module from the bracket.
• Disconnect the electrical connectors.
• Reprogram the communication interface module after replacement. Refer to
Control Module References.
• When replacing the communication interface module be sure to transfer Bluetooth Antenna, if equipped.
I am having a hard time removing the old vcim. There are 2 silver brackets where the bottom of the vcim should slide out that it is catching on. There are also 2 bolts in those silver brackets, but I cannot even get it over the bracket to worry if the heads of the bolts will catch it as well. Am I missing something?
Here is a pic with the red lines pointing at what I am referring to:
You will have to view full size to see the red lines.
I have mine installed finally (i have the navi and bose system). When I say bluetooth, it says sorry, etc. Did your system have the navi/bose system?
Thanks to 07crewsierra!!!!! I have it working now. Was not saying Onstar at first when using the steering wheel button. Then you have to say Bluetooth. I was going by the instructions on page 2 and did not see where you had to say Onstar. But anyway, its working!!!! Have green light on left and after a few seconds after starting the truck the one on the right goes red. Now to get it in my G8!!!
The red light must be tied to OnStar not resetting......some on this site say it will reset in a few days.......you should call them if your still using OnStar. I thought when you get a VCIM from another vehicle where it was previously working then you DID NOT need to have it programmed like a new VCIM?
Not using Onstar anyway.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
