Bluetooth Options For 2008 Silverado
Scott, where in the devil did you get that chart?!?!
I've been looking for that information for MONTHS and gotten nothing.
You can get the same information from TIS2WEB:
http://tis2web.service.gm.com/tis2web
Just enter in any VIN and choose the VCIM. I just noticed that 2007 and 2008 models don't have VCIM info in the system for some reason...not sure if some vehicles were left out or what.
I just flipped through the pages that link goes to and thats exactly what I just did at the dealership yesterday and we got the message "Programming Successful"
Are you saying that because I put in my 2007 VIN it actually didn't correctly do the setup, so I need to enter a 2009 VIN to activate a Bluetooth VCIM because they only got released in 2009?
I ask because OnStar keeps telling me they are getting the error message on their end "bad model year software error"
Bad meaning it wasnt matching my VIN 2007?
Bad meaning it wasnt matching the software from the year they first produced BT VCIM software?
Answering this might help a few of us......
  • Replies 735
After doing a bit more looking in TIS, I would agree that's probably the key to this whole thing. We need to use a 2009/2010 VIN to pull up the appropriate software that also matches the specific type of headunit installed in the vehicle. If I had to guess, the reason RayGMC was able to get his OnStar activated without too much trouble is because the used VCIM he purchased came from a vehicle with a matching audio system in it already.
It also explains why I've been having problems getting OnStar to load the right software into my unit. My truck originally came with a 6CD changer in the dash, and I replaced it with an OEM Navigation unit. OnStar doesn't know this, nor does GM's database that pulls up information based on how the truck was built at the factory.
Well after going to the dealer for my 3rd ONSA TIS2WEB setup procedure (no charge) I would tend to agree with you Charlie. On* is telling me yet again they are getting error message "Invalid make or model software" and they cannot complete the download setup from their end.
Im confused though.
Are you saying when we got CW to programm the VCIMs we should have used a 09 VIN or when we do the ONSA TIS2WEB set up we should have used a 09 VIN??
My Truck has had navigation radio all the time and CW knew that when he programmed the VCIM.
I just put in our VCIM part number 20783877 and TIS2WEB page says invalid part number....WTF?
Im confused though.
When Chris did the programming it was necessary to use the VIN from our vehicles because that is what makes the vehicle and module recognize each other. I'm saying that we should be using an 09/10 VIN to pull up the proper software to flash in during ONSA. I don't think that what Chris did would have been dependent on the audio system.
That is a GMSPO hardware part number; the TIS site is looking for SPS software calibration part numbers.
Im confused though.
So Charlie do you figure its worth a shot going back to my Dealer see if he will do the ONSA TIS2WEB setup with an 09 VIN from a vehicle with same options as me?
I am willing to go to the dealer and try it out next week. I figure they owe me a free set-up since the screwed me last time I was in. I can't get there before Friday though. Anybody got any good ideas on where to get an '09 VIN? Let me know if you guys think it is worth giving this a try.
-Kip
Entirely possible; that is exactly what I plan to do at this point: get the dealer to use their Tech2 to read out what hardware ID is in the VCIM I have, then use a 2009 or 2010 VIN in that TIS menu to find the correct software/calibration part number that matches up with both the VCIM and the audio system in the vehicle for them to use during ONSA.
If my suspicions are correct, it shouldn't screw up what Chris White already did, and if it does screw something up I'll just have to track him down and see about getting him to fix it (since it would appear he's either out of business or just on vacation, I'll just hope I can get in touch with him).
-Kip
You should be able to just pull the VIN off any brand new truck on your dealer's lot for this purpose.
-Kip
Find a truck for sale online that closely matches your truck with same options maybe.......thats what Im doing
Just to be clear, reprogramming / reflashing with a different VIN could get you the correct software / calibration. However, I'm not sure if using a different VIN for the ONSA / onstar account learning is a good idea. This could link your VCIM module with someone else's onstar account. Not sure about that, as I believe each VCIM has a unique hardware ID (kinda like a computer modem), which they use to link your truck to your onstar account.
Scott
Scott
Scott,
To be equally clear, I'm not suggesting that the VCIM needs to be flashed with a VIN for a different vehicle -- actually quite the contrary. The proper VIN for the vehicle still needs to be present in the VCIM for it to work properly.
All I'm suggesting is that we obviously need to use the VIN from a newer bluetooth-equipped vehicle (regardless of what else it has in it equipment wise) in order to access the menu in TIS2WEB with the software calibration part numbers as you posted in chart form earlier. From there it's just a matter of matching up the correct VCIM hardware ID and the type of audio system in the older vehicle being programmed in order to choose the correct software calibration part number that needs to be flashed into the VCIM.
Guess my search is on for a 2009 with similar options. I wonder how close it has to be? Found one that is pretty close, but I have a crew cab and it is an extended cab. Close enough? I am willing to give it a try. Let me know if somebody gets around to it before I can get to the dealer on Friday. Good luck to everyone trying it this way. I haven't had Chris White work on my VCIM yet, so maybe it will give us an answer if it is required or not. Here's to hope!
Have you guys seen these AfterMarket OEM style Navigation Radios?........very close to OEM but you get built in BlueTooth and everythings on the radio display. Mapping Geo data is on an SD card so no more GM Nav Discs.
If you're looking to add Navigation and BT this might be worth considering.
http://cgi.ebay.com/ebaymotors/2007-2008-2...ht_13087wt_1199
There was a thread about those in the main forum a week or so ago; there were a couple links to reviews of the unit that weren't so positive.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
