High Rpm At Idle
To start I have a stock drivetrain on a 87 K-5 Blazer, 350TBi. The promblem is a high RPM at idle. It will go anywhere from 1200 to 1500 and stay steady. I have checked and replaced vacuum lines and Throttle position sensor as well as the coolant sensor which seemed to have the most effect on it.
When I drop it into gear it of course drops RPM to around 500 if sitting on the brake. Is it a computer problem or possibly another vaccum line I might have over looked?
If it is a auto tranny, 500 in drive is correct and any idle speed in park is irrelevant. Fuel injected vehicles have ISC as the IAC valve and for auto trannies 1000-1500 in park/neutral sounds about right. If it is a manual 600-750 is good. But just run some carb cleaner down the hole to clean any gunk that should be good to clean out the IAC passage.
Hmm, maybe the Idle Air Control Valve?. I know a couple of years ago I had the same problem with a '95 4.3L TBI. Ended up having to replace both the TPS and the IAC valve. If I remember right the IAC valve is next to the TPS (passenger side of the throttle body).
