My White '08 Crew Cab Silverado was damaged by a pipe kicked up by the car in front of me and dented my Bumper, Grill and Hood. Insurance is paying for the repairs, which will include a new grill. It occurred to me that this might be a good opportunity to replace the factory grill with a nice aftermarket grill.
Any suggestion/recommendation?
I think with the white grill there are inserts in it for a chrome instead of black in the spacing. I like the look of those. What is the color of your center bar below the grill?
White grill
Chrome inserts
White bumper cap
Billet bow tie
If you're really crazy you could even have the lower fascia pained white too and then grab some chrome tow hooks to top it all off.
Rich will let us all know when the fog light kit comes out too. That'd really finish it up.
White grill
Chrome inserts
White bumper cap
Billet bow tie
Werd.
I say color match everything. The color matched grille with the chrome inserts would look awesome. :jester:
+1
+10 I agree. White on White...!
Can't believe I said that since I'm a Chrome kinda guy. Just make sure you get all your ducks in a row before the body shop does the work. I wanted a custom grille on mine after somebody hit and run the front of my truck and the body guy had already ordered the stock one.
So I bought the aftermarket one anyways then sold the stock one...
Good luck. Sorry to hear about the pipe. Good thing it wasn't a few inches higher!!!
-Evan
I say color match everything. The color matched grille with the chrome inserts would look awesome. :lol:
:jester:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
