Holy Hell.
tobias
That dash is just fugly! As for the grill styling, what were they smoking?!
They must have gotten into my stash. :cheers:
The wheels look like they were trying to copy a plastic wheelcover. The grille is typically "new ford" ugly. The the cluster looks like a clusterfu.... well you know.
That instrument cluster... I haven't seen anything that ugly, since the KITT Super-Pursuit Mode car... Oh! Wait! That's a Ford too!! :cheers:
That's nothing more than a desperate attempt at redesigning a truck to look different and unique as possible. Seperately, some of those features actually look interesting. But a truck as a whole, none of that is working for 'em.
Wow, not feeling that. The instrument cluster looks beyond old school with those gauges up top. Then the radio buttons look like they'd be a real pita with the presets positioned the way they are.
Out of curiosity..... Which.. ones?
I like the MS Sync Sat Nav system. :cheers:
And... the door handles are nice.
I like the MS Sync Sat Nav system. :)
Actually, I think the profile view of the truck isn't bad.. It's the front and back that leave some to be desired... and that instrument cluster and overall dash ... :cheers:
Yeah, there's just a lot more stuff that's wrong than what was done right to give it a chance. Who knows, maybe it'll have better luck with the Ford guys.
Face it Michael, the truck just flat out sucks. :)
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
