Integrated Brake Control
rfinnigan
Just bought a new 2008 Silverado 1500 Crew with Max 6.0 and Intergated Brake Control. I plugged my camper in and all lights work but brake control does not work. It doesn't appear to see the trailer as I get no message of "Trailer Connected" etc.
My question is .. am I not doing something correct? It seems odd it does not function because the truck only has 500 miles on it although stanger things can happen. The trailer works fine connected to my 2005 F150 with factory connection.
Thanx
In my 99 Silverado 2500, I had to install/add a couple of missing 40amp Maxifuses to the underhood fuse box. One of the Maxifuses is for the brake controller. The other Maxifuse is for the 12v line to the trailer battery. Trailer wiring is prewired and included in the Heavy Duty Trailer Towing Package.
Corroded/dirty contacts in your 7-way connectors (trailer and truck) is a frequent cause of no-connection indications.
Other than missing fuses or dirty contacts, you could have a defective Brake Controller, a defective Brake Control Adapter Harness, or defective wiring.
The Tekonsha Prodigy brake control installed in my 99 Silverado is the best brake controller that I have ever used. It automatically levels itself and automatically adjusts the trailer brakes for level, uphill and downhill towing.
As I was checking my connections I did find that I had no aux power at the trailer so your reply Sparks was well timed. I only hope at this point that the brake setup for this trailer is powered by the onboard battery. I know that the trailer seperation braking does draw from the onboard battery.
We'll see when I get back with the fuse......
OK, did you connect the two under hood wires to the fuse block? One is for AUX power one is for trailer brakes. Was that a yes on fuses too? Two wires under hood, two fuses. At least this is how non-integrated controller trucks are. Maybe double check truck harness out put to trailer harness inputs. Make sure functions are in the correct positions in relation to each other.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
