What Do You Guys Think About This
well guys i was thinkin about buyin a new truck but i still love the way the 800's look so i'm thinkin about goin for a deal on an 06 i've been lookin at
19.5 ls z71 body lift procomp tires not sure on the type of rim... let me know what you think... i'm thinkin maybe tryin to get about 18 or 18.5 for her since she's already got 45k miles on her... what do u guys think? whats a good price for a truck like this?
Looks like a nice rig. You might have to spend a weekend removing some of the stick on accessories, but it's nice! I don't know if I'd pay over 16K for an 06... even with all of the accessories.
looks nice, I would start at about 17! worst that can happen is they say no and you offer more. I am the type of person if i offered 17 and they jumped on it, i would either wonder whats wrong with the truck or what they would say if i offered 16!
Good looking truck, but I'd look at the front suspension. The truck looks level, which means he either cranked the stock keys, or put on aftermarket keys. The truck looks like it's got a good amount of crank, so look at the CV angles, tie rod angles, and ball joint angles.
Get pictures if you can too.
thanks guys i appreciate all your help! i'm gonna go sit down with them this weekend and see what they'll do... i owe just around what my trucks worth so all i'm looking for is them to give me the right price and i'll walk out a happy man... wont take much either... so we'll see how things go... hopefully a little better than last time... :dunno:
After looking over that pic... I say lose the ventvisors and the chrome fuel door and drive it! It looks tough with that lift.
Good luck on getting it.
took a look at the truck yesterday... very nice dealership... truck is kinda shotty tho... not so impressed in person.. ran across another truck tho that really cought my eye... 2500hd... 6.0 18k miles for 20K.... kinda sparked my interest its a black 4 door... no cheesy stick on accesories...has some aftermarket rims... not to impressed bye... probably take them off and sell them if i bought it... and has the full running boards... not a fan of those either so i'd most likely dump those as well... but other than that... the trucks in immaculate condition.. has one of those sweeet hard roll up covers that rolls up in the front of the bed like a mini bed box... still a brand new truck its an 05... so we will see... i'm gonna try and see what i can get for my truck... i'd transfer the grill guard, cb, and a few other things but heres what the 2500 looks like...
anybody know what kind of gas milage the 6.0 gets? just a ballpark?
note: remembe rthese rims will be history if i buy this truck! :cheers:
says its an o5 but i think that they switched the grill out on it i didnt ask too many questions cuz i was kind of in a hurry to get back home but thanks for bringin that up i'll have to see!
are we allowed to do vin checks still?
Are you sure thats an 05? Looks like it has the 06-07 classic grill on it....
Yep,It can be an '05,They started that grille/hood on the HD's in '05,Then added them to the 1/2-tons in '06.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
