Called Around For Body Lifts
i called around for body lifts and a leveling kit and they were saying that all of my arms are going to go bad and they were trying to sell me a 4.5 inch lift kit are they just trying to scare me into buying it or is it something that i should really consider? or should i just go ahead and get the body lift and leveling kit? and another question they were going to charge me the same price as it is for the kit for the labor for them to install it is it that hard to do or is it something that i could do in a driveway? thanks
Whether or not you'll do damage depends on how high you expect to go with the torsion bar cranking.
As for your last question, if you have no idea how to install a body lift and a leveling kit, you'll probably want to let someone else do the work, IMO.
I think body lifts are junk, personally. If you are going to lift your truck, lift it right. :thumbs:
Well body lifts ARENT junk, there is nothing wrong with one of these, i have one and love it. Yes, if you have the moeny and want to do it right, then you need a real lift kit, a leveling kit is just cranking your torsion bars, which mean harsh ride, bad tire wear because you front end cannot be aligned properly, and in the end components will fail. It jusst cheaper to go ahead with a real lift if your are going to do it, what size tire you wanting to run??
Hey Justin, I think you should remove the "b" from your username and then give it to daddy to use. It would fit him perfectly. :thumbs:
Maybe you should abide by your own sig and STFU. :lol:
The body life won't affect the suspension. Though just cranking up the torsion bars using the keys can cause suspension problems. A torsion crank only of .75 shouldn't really cause any issue. There are lots of folks here that have a leveling kit and haven't had any problems. If you want to take the suspension in general any higher really, a proper lift would be the way to go.
Yeah, maybe I should, but I ain't gonna. :lol:
can i get my truck lifted 4.5" and still rock my stock rims and tires buecase this was more than i was expecting to spend on this i already have the rims i just need the tires and with a 4.5 can i rock 35" tires on it?
LOL....naw you the one that needs my s/n without the B,
sry Tobias, i wasnt getting mad, i was just letting you know i had a b/l.....lol
btw, take the fat women off your avitar!!!!
:thumbs:
well they really dont make a 4.5" lift for our truck, i think skyjacker claims theirs in 4.5 its really 6" and yea you can rock 35's with minor trimming..... Just to be sure what brand lift kit was it?
I don't even have a lift, who cares what I think? The last body lift I put on a truck was a buddy's Ranger in '93. I just don't like the concept is all.
The big girls are stayin' :thumbs:
    • Sir, economics doesn't have a moral compass. 😉 Just say'n.
    • One would think. BUT....This is what a Google search gives for the GM OLM system:    It doesn't measure oil condition save the highly indirect water temperature. It should measure oil temperature and as we've discussed they are not as closely related as one might assume. The algorithm is based on expected conditions at the end of a certain number of miles or revolutions. And sirs, this estimated value is not tilted in the engines favor. It favors the OEM's bottom line. There are no magical number of miles nor revolutions. No magical time limit. There is only what can be measured directly and only in the broadest of terms would the values used even come close to reality.    It samples nothing. It has no idea where the oil started or where it will finish given the limited values use to create the algorithm. It is just a reminder for the brain dead to do something at some time to keep the warranty in tact. Pure fiction.    Key Factors in Oil Life Calculation The OLM calculates the remaining oil life percentage based on the following factors: Factor Description Engine Revolutions Tracks the number of engine revolutions since the last reset, decreasing oil life with use. Mileage Since Last Reset Monitors the distance driven since the last oil change, capped at 7,500 miles for most models. Time Since Reset Decreases oil life over time, dropping to 0% after one year, regardless of mileage. Engine Temperature Adjusts oil life based on coolant temperature; exceeding 260°F sets oil life to 0%.
    • Towing power and I guess MPG matter that’s why I may end up going with a gear swap as soon as they’re available for this truck if I’m correct
    • If I may, I'd like to post my prediction of the trim levels for the 2027 GMC Sierra, based on what was released/introduced today about the Chevy Silverado.   Using the "Professional Grade" wording already in use by GMC, here are the eight (8) trims I believe the Sierra will offer (comparable Chevy trim in parenthesis): Sierra Pro (Work Truck/WT) Elevation (Custom) Elevation Premium -or- Ultimate (Silverado) AT4 (Custom Trail Boss) AT4 Premium -or- Ultimate (Trail Boss) AT4X (ZR2) Denali (High Country) Denali Ultimate (N/A) If GMC would rather simplify the trim levels, then I predict six (6) with package upgrades in parenthesis: Sierra Pro (with a Graphite package upgrade option) Elevation (with a Premium -or- Ultimate package upgrade) AT4 (with a Premium -or- Ultimate package upgrade) AT4X (with AEV and Ultimate packages upgrade) Denali Denali Ultimate  Let's see if I'm close.
    • I have to believe there are already a bunch of threads on this, but my searches didn't turn up much. While I like the ease of a plugin solution like the Carbyte, It appears it disables the AFM or DFM too, and is not configurable to only disable the auto stop/start. So, I'm looking at the Autostop Eliminator product. I like the idea of it better, but I'm concerned about the install and having to pull so many panels to get it installed. Mines a 2026 work truck, so from what I've read it's a less involved install, but having watched a couple install vid's, I'm still a little intimidated. Might need to buy some plastic trim tools to get it done without breaking or marring stuff. Any experience intalling in a WT greatly appreciated.
