Transmission Conversion
Hello Everyone,
The 4l60e in my 2005 1500 ECSB 4.8L is on it's last legs and I've been thinking of attempting a conversion to a 5spd manual, either nv3500 or nv4500. I've been doing a lot of internet research about the transmissions themselves (bolt-in, length, gear ratios, cross-member, transfer case, etc.) but I'm having trouble visualizing the location of the master cylinder and the clutch pedal setup.
I crawled around the truck yesterday and it seems like a really, really tight fit for the clutch cylinder beside the brake booster. If anyone here has a 5spd could you post some pic's of where exactly the master cylinder is bolted to the firewall as well as a couple of pics of the clutch pedal assembly and how that is bolted in under the dash? I'd greatly appreciate it.
Thanks!
I didn't do much to the tranny myself. I bought the truck last summer with 95k miles... it now has 115k. When I bought it the dealer said it was probably used by a construction foreman that racked up all the miles going from jobsite to jobsite. The interior was perfect, not a speck of rust, hardly any dents or dings, so I thought I'd take a chance on it.
I've got some slipping issues and the tach is wavering up and down at highway speeds. The first guy I took it to said it could be servos but with 115k a rebuild is just around the corner.
I was just thinking of swaping in a stick for long term durability and as a hedge against the cost of another 4l60e rebuild down the road.
That's a good idea about checking one out at the dealers lot. If nobody has any pic's I guess that's what I'll do.
The cost of conversion and the downtime will not equal the cost of a rebuild.
I agree. Many are getting 150K without hesitation out of the autos. By the time you buy all of the necessary parts to convert yours, you could be cruising another 100K with the AT.
  • 5 months later...
Saw this thread and thought I'd add my .02. I have a '01 2500HD-6.0L-reg cab-Longbed with a NV4500 5 spd. 184K on the truck and have had 3 slave cylinders thus far. Try to find a 6 speed out of an older 8.1L if you can. The NV4500 is really just a 4 spd as the 1st gear is a granny. The tranny requires a special lube called Syn-torque made by Castrol and it's a dealer only item
