Lubricants/fluids Survey
I'm thinking of changing out all of my fluids in the truck and I'm hoping some people could share what brand and type of fluids/oils you use. I have the Autotrac system on my truck.
Transmission:
Transfer Case: (heard GM AutoTrak II is the only way to go)
Front Differential:
Rear Differential:
Engine Oil:
I'm not looking long winded studies or anything. Just curious what people are using.
Transmission:
Front Differential:
Rear Differential:
Engine Oil:
Trans - Dexron VI
T-Case - Dexron VI (Spec for my t-case (AWD) instead of Autotrak)
Front/Rear Diff - Amsoil
Engine - Amsoil
Transmission:
Amsoil ATF Dexron VI
Amsoil ATF Dexron VI (note-07 NBS up use ATF, 99-07 Classic can only use AutoTrac fuid
Front Differential:
Amsoil Severe Gear 75W-90
Rear Differential:
Engine Oil:
Amsoil SSO 0W-30
Miles on vehicle 12,000+
Miles using Amsoil 11,000+
Engine---Castrol Syntec European formula made in germany 0W30 group IV PAO synthetic, can only be purchased at Autozone.
Trans---- Dextron VI
Diff------ Castrol Syntec 75W-90
Chassis grease- Mobil1 synthetic
Brake fluid- Castrol GT LMA Dot-4
Radiator- Dexcool
Gas------ Shell
Me------- A hot cup of joe every morning
Have a good one, :cheers:
Don
The german made Caatrol Syntec 0W30 is a kick arse oil!
I'm using it too, have been since 8k miles. No problems so far, but not that I was expecting any problems...lol.
Just recently changed my rear diff fluid to Royal Purple also. Haven't changed the tranny fluid yet but I may do that in the Spring, and install a tranny cooler at the same time.
Transmission:
Did you do a complete flush or just drop the pan to change the fluid/filter/gasket?
Thank you for all the replies folks. The plan right now is to go with Mobil 1 for engine oil (they didn't have any GC 0W30 in stock), and Royal Purple for the front/rear diffs, Royal Purple for the tranny, and Autotrak II for the transfer case.
Complete flush using purge method, drop pan and inspect (no debris found in pan), keep oem filter (only 1,000 miles on new vehicle), fill pan and then disconnect cooler lines and run 16 qt thru to make sure all of the oem ATF was gone. All work done by ASE trans pro's with my supplied lubes. Had them do both axles at the same time. I have used this shop for many years and they are experts doing this, took about 1-1/2 hrs at $50hr labor. I send them about 1-2 customers a month. No machines in use at this shop, mention one and they say a silent prayer because they are the shop who fixes all the trans mistakes the local quick lubes create with the flush machine. He jokingly told me he would have to lay off 1 person if they stopped using the flush machines.
The GC 0w-30 is only available at Autozone. I have used it and it is great stuff. Since then I have moved on to Amsoil
Transmission: Whatever came from the factory (I do not do any heavy duty towing)
Transfer Case: Whatever came from the factory
Front Differential: Whatever came from the factory
Rear Differential: Whatever came from the factory
Engine Oil: Used whatever oil the GMC dealership used for the first 10,000 miles, then switched to Mobil-1 5W30 Full Synthetic with an AC/Delco oil filter. I change the oil every 5000 miles, which is usually every 6 months for me.
Fuel: 85 Octane, Any major brand. Usually Conoco, Phillips 66, or Chevron (when in a state that has Chevron)
Blinker Fluid: Amsoil
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
