Thinking Of Debadging My Truck
BuckFeverZ
Yes, I know I am usually against debadging trucks, but I think once I get my leveling kit installed it will look much cleaner without the badging. I am thinking of leaving the Silverado emblems on the doors but unsure yet. Mainly I'd take the Z71 and the stickers off the side windows. If someone has time and wants to PS it, I would appreciate it :D
Do it!!!
Your smartest post EVAR!!! :cheers:
Yeah I have been getting that a lot lately.. I guess it makes up for the overload of stupid 100 posts + per day!!! :D
FTMFW! :D
Follow that up with some painted or chrome handles and mirror caps and you'll be set.
I'll send you the set of chrome handles I had on my truck if you cover the shipping. They are the actual handles, not the covers.
FTMFW! :lol:
Look's a lot better. :thumbs:
FTMFW! :D
Thanks Tobias! :D
I actually really like the way that looks. Also, I got chrome mirror covers for Xmas so I have them on right now (no pics), but I would be interested in those handles, let me know how much shipping would be. My zip is 53583.
FTMFW! :D
Thanks Tobias! :lol:
That actually looks really clean....hmmmm....
:D
FTMFW! :D
Thanks Tobias! :D
I'll have my secretary check in the morning but I doubt it's more than $5 - $10 bucks.
You did notice the window sticker was gone though, right? :lol:
Daddy, only ship the handles to him IF he removes at least some badges, and ALL the stickers. :D
That's a damn good idea! :D
do it for sure!! I did this to my truck also and I keep the sierra on the door and I think this is the best thing I did. Makes the truck look so much cleaner. And also get the chrome handes. That is a steal if you are just paying shipped even if it is $10-15.
Can't wait to see it debadged and leveled. Just wait on the debadging until it is warmer!!!!
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
