Best Mud Tires For 1997 Silverado Z71
I want to put a set of mud tires on my 1997 Z71 and i would like a wide tire that wont rub and has decent wear on the road. I am puttin them under a stock susspension no lift at all. I dont want them to rub my fender wells and I would like an agressive tread. What size and type should i use?
I'd suggest a 285/75-16 BFGoodrich Mud-Terrain T/A KM2. Stock K1500 tire size is 265/75-16; these are an inch larger at 32.8" vs. 31.8". Any larger than that and you risk rubbing and needing to crank the torsion bars. If you're going to be doing road driving most of the time (just the occasional off-roading trip), then the All-Terrain T/A KO would probably be a better choice unless you don't mind paying more money more often for Mud-Terrains, but from what I understand they clog up easily. However, they'd still be way better than highway tires. I plan to get the All-Terrains once my Michelin LTX M/Ss eventually wear out, but I bet they'll last me a few more years with my driving.
With a Stock truck, go with 285's. They wont rub and they will look great. You wont have to crank anything either.
As far as type...if you can find a dealer, i has summit mud dawgs, same as maxis bighorns. They drive really well on the highway and have alot of sipping (BFG MT's have none) and do really well offroad. I have 44K on mine and will probably get 3-4 more.
And they are goiing to be cheaper too
http://www.offroaders.com/tech/AT-MT-Tires...762-BigHorn.htm
There is a link to the Bighors...and if you look to the side there are alot of other mud tires you can look at the ratings of.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
