Finally Lifted!
:mad: real nice looking ! I thought lift mine too, but no knew how much, I see your truck and think that i do the same 4", very nice, not too much, that's perfect !
  • Replies 42
Looks really nice. I want to do the same lift on my truck. I just realized though that I can barely get my truck in the garage at stock height, so working on her will all have to be done outside. Damn raised ranches with the low garages. I should sell my house for something with a bigger garage.
No doubt, looks great! I have the same brand, body style, color, wheels, and also live in VA now. I've been thinking the 4 inch is the way to go for months now. I'll also be curious to know what your mileage is doing. Where did u get it installed and I'd also like to know how much the install was?
That looks great, pictures look like magazine shots too, awesome. I just got the same lift, one of the best out there IMO with the solid subframe, it's QUALITY. I went with the 5000 series shocks to save a few $, hope I don't regret doing so.
  • 2 years later...
Looks GREAT as is, but would be perfect with a set of 305s. I'd just drove this set until they're gone, it's not like they look tiny or anything. :cheers:
i was gonna do the pro comp, but i really love your truck. got me thinking maybe ill do the rancho. i was plannin on doin twenty's on 33's but i like the look of the stock 17's. would save some money too.
i know u said they are 33's but what are the number of your cooper stt's? thats the tire i wanted to because of the light weight so i wont lose much power and keep close to stock gas mileage as well.
I actually like the stock wheels with the lift, I may be the only one. I really don't like most of the wheels I see, but I've always been a fan of stock wheels.
+1
  • 1 month later...
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
