A/c Turns On
Is it normal for the A/C to turn on when you start the truck and the A/C button is off, but the recirculation button is pressed in? This happens to my truck. Is something wrong with the A/C switch or is it purposely configured to do this? None of my other vehicles does this. The A/C switch and the recirculation button are independent of each other.
normal, recirc runs the AC compressor.
Yep, but it only runs it under certain temp conditions, and will turn off on it's own. At least that is the way mine works.
I believe it shuts off based on low temps right Jeff? It is normal op for the AC to be ON when the recirc button is pressed.
It also turns on with the defroster and anytime you hit "AUTO" on the climate controls but the compressor should shut off if the outside temp is below 40 or so.
    ar0517
    ar0517
  • Who's Online   5 Members, 0 Anonymous, 682 Guests (See full list)
