New Guy From Shirley, Ma
Lankhimself
Hi guys,
My name's Pete and I'm from Massachusetts. I just bought an '06 GMC Sierra SLT Z-71...it's loaded to the teeth. Bought it this past Monday and just took delivery yesterday. Love the truck, such an obnoxious upgrade from what I had before. We got a great deal on it and I'm so happy that my three-month search for a new truck is finally over. As you can see, I wasted no time finding a GM forum to peruse.
I'm 21 and am a full-time student and I work pretty much any time I'm not in class. Looking forward to getting to know the forum and making this new truck my own, I have a few plans but money will be a lot tighter with the payments!
Some pics:
and my old ride, '97 Ford Explorer...had over 110k on the clock when I traded it in, that, and it's was also bare naked. All of that stuff had been taken off and is on craigslist now :D . It was my frist truck, can't complain much, but she needed to go.
Nice truck man and welcome to the site. I live in NH so your not too far away.
Welcome, and congrats on the purchase. I like those wheels a lot. :D
Got anything planned for the truck?
Thanks man!
Yeah, I've got quite a few things planned for the rig, but like I previously mentioned, money is going to be tight! The things I need/want the most right now is a back rack and a tool box, both of these I scour craigslist for daily. I've got a box of electronics that need to find a clean, suitable place in the truck with as little modification possible - CB radio, Scanner, etc. I also need to make a switch panel because I have to have my off road lights, auxilliary reverse lights, strobes, etc. A brush guard at one point is a must, it gives me something to mount my lights on and I'm always in the woods and love pushing shopping carts out of parking spaces :cheers: . At some point I'm getting the exhaust done and probably adding a full intake, Volant, I hope. I have a secondary tranny cooler sitting in my room as well as a remote tranny filter (both from B&M) that I want to install...all with due time! Spring break will be busy!
Thanks man!
Yeah, I've got quite a few things planned for the rig, but like I previously mentioned, money is going to be tight! The things I need/want the most right now is a back rack and a tool box, both of these I scour craigslist for daily. I've got a box of electronics that need to find a clean, suitable place in the truck with as little modification possible - CB radio, Scanner, etc. I also need to make a switch panel because I have to have my off road lights, auxilliary reverse lights, strobes, etc. A brush guard at one point is a must, it gives me something to mount my lights on and I'm always in the woods and love pushing shopping carts out of parking spaces :D . At some point I'm getting the exhaust done and probably adding a full intake, Volant, I hope. I have a secondary tranny cooler sitting in my room as well as a remote tranny filter (both from B&M) that I want to install...all with due time! Spring break will be busy!
Sweet. :cheers:
I see you have a Celtics avatar, this wouldn't mean that you're a Sox or Pats fan, would it...? :lol:
:D
Thanks man!
Sweet. :cheers:
:D
Ahem....as you can see, Dan is not a fan of those teams from the Boston region... :D
And welcome!
Thanks man!
Sweet. :cheers:
:D
GO Red Sox!!
Go Patriots!!
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
