Any 49ers fans
Firetiger(MN)
Good game today.  Brett is an awesome 4th quarter QB.  He's really the only reason I watch green Bay play, but GB and the Rams should be a great QB battle -
Marty is out at Washington as of tonight.  Maybe Spurrier will get this team on the right track (with a decent QB as well).  Hard to blame Marty when you have a washed up QB.
It was a good game until the 4th quarter.  I was pulling for San Fran soooo hard since I'm a Bear fan and don't want to see the packers sucessful in any way, shape or form.  Anyway, the 49'ers practically gave them the game with that interception and then the fumble on the return.
Go St. Louis!!!!!!!!!
???49er fan -  Ended the way I thought it would...but O well, they did better than I thought they would this year. Remember up in Canada here we have a team that has the same team colours as the Packers (Edmonton Eskimos) and there is no way I can pull for a team that looks like them. Ask Jeff Garcia...he was here for 5 years, he knows how us Calgary Stampeder (2002 Grey Cup Champs) hate the Eskimos.
So I guess I will make a prediction for the super bowl...now that my odds are better. Lets say Steelers / Rams with the Steelers winning.....any response to that?
ps You are rightthough, there is no better 4th quarter QB than Farve.
Maybe San Fran should've kept Rice.  He showed up big for us Raiders fans.  :(
As for the Skins, Marty had them on the right track by the end of the season, I think they may have screwed up letting him go right when he got the team working together.  I don't see alot of the veterans putting up with Spurrier's crap.  But I may be wrong.
Oh yeah,
GO RAIDERS !!!!!!!!!
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
