Front Swaybar For '74 C-10 2wd?
DeppvomDienst
Hi-
I also just posted this question in the classic trucks forum as well but thought there might be more responses to be had here: Thanks in advance for your help.
I have to rebuild the front end on my 1974 Chevy C-10 2WD shortbed so that I can get a state vehicle inspection sticker. When the guy at PST asked what the diameter on the swaybar was, I went "DUH" since after all these years, I had no idea.
Cut to the chase: I went out and crawled under the truck and there is no sway bar and no evidence that there ever was one there. In my Chilton's, one of its "typical" illustrations shows that they were installed. I even looked under my '69 Impala to see about where Chevy attached the bushings to the frame and checked my truck again but could find nothing.
Does anybody know if these trucks had one? Would it be recommended to try to install one for better handling or better to leave well enough alone? Just for grins, it is an original 350 with a 2 barrel rochester and manual saginaw trans with 3.73 rears.
Thanks for reading my post,
Vinny
I bought a new 1974 1/2 ton with the 454.
I am "ALMOST" positive that it had a sway bar in the front.
That was a long time ago. :thumbs::fume:
Yep. '74 had one
Yes install one.
+1, Vinny you can usually pick one up from some of the aftermarket suspension suppliers. It's been years since I've installed one but it is a pretty easy job to do. Sometimes the frame and lower A arms are already drilled for one. For some reason back in the day they didn't put a sway bar on everything? :smoker:
Thanks everybody for your comments. My frame rails are missing the brackets that are depicted in the illustration that the sway bar bushings bolt to. Based on the feedback, my guess is that those brackets might have been specific to C-20s and up. Also it would seem that these brackets came welded to the frame rails...
Thanks again,
Vinny
Yep. '74 had one
Yes install one.
Thanks again,
Vinny
Yep. '74 had one
Yes install one.
No welding,all bolt-on.Here's a pic of the bushings I bought thru the 'net.I saw similar @ Autozone.These were meant for my '77 but my son wrecked the truck before I could use 'em.
you might look for bolt holes that are filled with dirt and grease,they may be there just covered.
    Bulldogger
    Bulldogger
  • Who's Online   4 Members, 0 Anonymous, 847 Guests (See full list)
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
