Water In Front Differential - 07 Avalanche 4wd
Help!
My truck is in the shop (Chevy Dealer) for routine 50k maintenance. When changing the front diff fluid, they noticed a significant amount of water in the fluid, and recommend that the diff be opened up looked at and possibly rebuilt as a result of the water. Of course, they are saying this is no fault of GM, that I must have had it submerged for the water to be in it. I can absolutely CERTIFY that this truck has never been in water except for rain... nobody but me has ever driven it. I bought it new! They are telling me I should call my insurance company. I don't want to do that... as far as I'm concerned this is a GM problem and they should fix it. Absolutely ridiculous that I'm facing a front end rebuild at 50k.
I found one other post with a similar problem.. I'm hoping someone has an answer about where the water came from.
Trent
It might just be condensation which is normal, especially if the front axle see little use. Do you live in a humid local?
I would be highly suspicious of this and not consent to any repair. Even if it ran this long with water it, there is no reason to think it will fail anytime soon. I think they are crying wolf to make money on the repair you don't need. Drive it 5,000 miles and change the fluid again but go somewhere else.
I agree, I wouldn't have them do anything without a second opinion. Just have the fluid swapped, and move on. Sounds like someones trying to make money off you. Did you see it for yourself? It makes me mad when a dealer will say.. nothings wrong,... nothings wrong,.. then when the warranty is over, FOUND SOMETHING!. Besides, isn't the front diff's considered part of the driveline under warranty?
Steven
Steven
yeah the front differential is covered under the 5/100K warranty but only if the dealership says that it is due to a defect...they said that it is not due to defect that all the water is in the front diff.
Somebody else posted about this same exact situation just recently
Edit: I see in your post where you already located the other poster.
Yes it is part of the 10 year 100K mile power train warranty. The reason they are saying it is not, is because GM will expect a reason for the warranty claim that they won't be able to provide. So if you repair have them repair it as non warranty work, they get the cash and have to offer no explanation except to you.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
