  • 9 months later...
Chiming in from Bartlesville, Oklahoma!
  • 4 months later...
I'm in Guthrie. Grew up in Oklahoma but born in Atlanta. Anyway, just bought my first GMC in October and just now stumbled across this post.
  • 3 months later...
BA IN DA HOUSE I work in owasso and frequent the hardrock's Friday night seafood buffet;)
I live in Broken Arrow, I work out at the port and bought my truck in Owasso.
Edited by iCryWheniGoPoop
Is it true y'all roll your joints all wrong? :pimp:
I'm originally from Colorado, I'm real good at the above comment.emwink.gif Currently live in Lawton.
As a kid I lived near Muskogee for about three years.
  • 5 months later...
Live in broken arrow
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,138 Guests (See full list)
