Chrome Wheel Simulators
I recently purchased a set of chrome wheel simulator covers for my 2002 Chevy dually. I love the way they look but the sqeaks are drivinng me nuts! Makes the truck sound like a buckets of bolts driving down the road. Any ideas how to make it stop, other than removing the covers? Rusty
It's a bit of a bitch but I have an answer that has worked several times for me.
Pull off the covers. Buy a tube of clear 100% silicon. Put a bead of silicon anywhere the simulators touch the wheel. A thick one inch bead every 4 inches or so seems to work. Reinstall the covers while the silicon is still wet. It forms a rubber like barrier between the wheel and cover and kills the squeaks. Do this when the truck isn't going to be driven for a day or so and the silicon has time to set up. The covers will still come off if needed with a little effort and the silicon can be reapplied if needed.
I helped a buddy use this method on his wrecker fleet. It works!
OK..I'll plead dumb on this one but I have to know...WTF are "chrome wheel simulator covers?" :thumbs:
Fancy name for hubcaps.
:lol: wow! just wow!!! :D
Thanks Zembonez...I learn something new everyday here!
:) wow! just wow!!! :)
noob.... :D
OK..I'll plead dumb on this one but I have to know...WTF are "chrome wheel simulator covers?" :cheers:
noob.... :D
alljackedup...please remove that picture of my future wife from your signature! :idiot:
I just purchased abs plastic wheel skins for my 2500 HD, they are like simulators but plastic instead of chrome or stainless steel. My stock gray wheels underneath were rusting,painted them before installing wheel skins. plowking
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
