Leaking Rear Diff
Ok, so I changed my rear diff lube like 2 months ago with amsoil, and a new gasket. Everything went fine, no leaks then about a week ago I notice a spot appeared on my driveway and soon enough several more appeared.
I got under my truck tonight expecting to have to tighten either the fill bolt or the bolts holding the cover on. What I saw was fluid that appeared to be leaking from where the drive shaft meets the diff...
Anyone ever seen this before? What does this mean? Can it be fixed?
Your help/input is greatly appreciated.
Holy crap! That just started to happen on my truck today too! What the hell, you know? I need to know what to do also.
It's called a rear pinion seal. Others here will chime in on the replacement procedure, but it does involve things like crush sleeves and in/lb torque setting to get the pinion/ring gear contact surface correct. I'd advise heading to a shop to get it replaced. Good luck.
I am gona check my overflow/air tube in the morning and see if it clogged. If not then i guess the pinion seal needs replaced.
How many miles on your truck? Now I have to check mine. Hopefully no leaks. Did GM start using cheap seals or what? These seals normally do not leak for many years. I had a lot of rear drive American cars in the past and never had a leak coming from the differential pinion seal.
This is not an armature repair. You need special tools to do this job. Mess it up and you will have to have the rear end rebuilt!!! It is the pinion seal as stated above.......
Jbo
i have 78k on mine. i just had new ring and pinion installed 6 weeks ago and no leak. all of a sudden it started leaking this week.
Yep. Seen Amsoil do that to a few seals.
is it because it is fully synthetic or what? I need to know, cause the shop i had work done put in Royal Purple gear oil. Is that the cause?
I used Amsoil before and no leaks, so I don't really know what to think about this situation.
OH NOOOOOO.... wow... that's all I can say. I thought this stuff was supposed to be the best??
Anyways, thanks for all your quick replies. A couple of questions now:
1.) Can I just top it off for now until I can have it repaired? I may not be able to have the funds for this for like another month or so.
2.) what should I expect to pay for this?
**Edit... I have 169K miles on the truck
THX!
dude, i think the first thing to do is check the fluid level, then the air tube. I just read about pinions leaking if overfilled, and mine didn't leak until this week. coincidentally, i added as much fluid as I could to the maximum amount allowed per GM recommendations. I am gonna let some out tomorrow and check my tube.
You may have overfilled it. Seems like your leak and mine are on about the same timeline in regard to synthetic fluid, fill, and weeks.
Jbo
Armature repair? :rolleyes:
Try amateur.
How do you check the level? I don't have a fill hole in my cover, it's towards the back of the diff. And yeah I filled mine up to what GM called for, I think it was something like 3 or 3.5 qts??
holy crap dude, i don't think it takes 3-3.5 quarts! that is A LOT. Usually 2 quarts puts you at the right level, not too high and not low.
You check the fluid level using allen wrenches in the fill hole (the fill plug you put a 3/8" drive in - the actual square part-, seen in your first pic above).
i think the highest level you want to see should touch the bent part of an allen wrench that is 5/8" down into the hole. The lowest is like 1 3/8" or more. I may be off on the exact number, but I do know if your fluid level is at 1" below that fill plug hole you are money on the fluid level.
someone here has to know the max and min level heights.
BTW, I added an aftermarket diff cover and it holds an extra 3/4 quart of fluid and I still did not get up to 3 quarts, so if you put that much in you got to let some out.
OK sorry I ordered 3 qts, and must have put them all or close too it. Maybe I overfilled it.
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
