Need Help With Correct Tire Size On 2009 Gmc 1500
gabet95
hello everyone,
I'm a nubee to the forum, but definitely not new to GM cars and trucks. This is actually my 3rd GM truck and I have to say, this is the best truck i've ever owned.
I just recently bought a 2009 GMC Sierra 1500 Crew Cab 2WD and I'm trying to accessorize it a bit.
Some of the mods that I've already done are: AMP power running boards(bad ass), 6000K High/Low HID Kit, Fosgate sound system, 2.5 inch front leveling kit, chrome door handles, AMP bed-extender, Denali style grille, and Moto Metal 956 17X9 chrome (NOT installed).
I just bought a set of wheels, but I'm stumped on what size tires to go with.
The wheels I bought are "Moto Metal 956" 17X9 w/4.5 backspace and -12mm offest. I want a more aggressive looking stance where wheels and tires stick out slightly, I'm not really big on the OEM setup where the wheels/tires are flush with the fenders.
I guess the big question is. What is the biggest tire I can fit without trimming or having rubbing problems? Remeber I already leveled out the front which raised it a full 2.5 inches.
I'm getting mixed suggestions from different folks. Some say the biggest tire I can fit is 285/70R17 and others swear 315/65R17 will fit with room to spare.
Any feedback from members that have actually used larger tires would be great.
Thanks in advance for any help.
do some 285/70/17
Is that the size your running on your truck in the pictures? If so, are you having any rubbing issues?
Thanks for the feedback.
Anyone else want to chime in?
With that wheel width and backspace, expect to do some trimming with the 285/70/17s
What wheel width and backspace would be ideal to run with this size tires? I know folks running stock "OEM" wheels are having rubbing issues when running this size tire on factory 17 inch wheels.
Thanks
    LonghornMM
    LonghornMM
  • Who's Online   5 Members, 0 Anonymous, 543 Guests (See full list)
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
