Ooo...gotta Have It...
I don't think your truck needs that. It's just too gaudy.
+1
I agree it would look SICK. Not in a good way. :jester:
Your body style is one of the best looking trucks gm has made. Don't screw it up.
Your truck looks great now.
WHAT the 1990-1998 ext cab is the best style ever made on any truck period. its got that tuff look but its not a box.
anyways sometimes those can look good, but i dont think they would go with your truck. i could see them on a lowered 2wd. its up to you man, your trucks good look good either way with all the black you got going
Brandon,
Did you ask everyone what they think of your girlfriend's looks before you picked her? Personally, that look isn't my taste, but I say, if that hood is what you want, you should have it.
HAHAHA...now that was funny...and a good point!!
keep in mind also that after shipping/purchase you have the necessary prep to get after market fiberglass to fit and look decent then paint.Buddy of mine bought a similar style hood for his 95 Impala SS....same initial cost...but the finished product was $1500 after getting it to line up close and get the waves out...and it was from a well known manufacturer as well.
My problem with this hood is that the picture supplied only shows the nose of the truck....often the entire view of multiple angles tells a completely different story.I have seen a hood very similar to this(might be the same?) on a black chevy late model....very overstated in my opinion...makes the rear of the truck look like its missing something.
My advice would be to try and find some more detailed pics and see if you still like it.
hmm, very good points. and thanks for the complaments on the truck :devil:.
and if your buddys dont find your gf hot...time to start lookin for a new one! :jester:
hmm, very good points. and thanks for the complaments on the truck :P .
and if your buddys dont find your gf hot...time to start lookin for a new one! :lol:
Pics and we'll let you know. A little skin is always helpful.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
