Mixing Conventional And Synthetic Atf
Hi All,
I'm thinking of moving to synthetic for my 2003 Yukon XL, with about 57k on it.
I don't have the parts and I don't think I'll be able to do the "manual flush" like this, and I'm wondering if it would be a problem to just put in Amsoil ATF, or some other synthetic ATF. Drop the pan, drain the fluid, change the filter, then refill with Amsoil. I understand this is going to leave about 50% of the old fluid in the vehicle, so I'll now have 50% convention and 50% synthetic.
I'll likely drop the pan and drain again in short order, perhaps 6 months or 10,000 miles, whichever comes first, and then again 6 months later or 10,000 more miles. I figure that way I'll get most of the conventional ATF out and have it replaced with synthetic.
I've searched and read a ton on transmission fluid changes, and it seems that the general consensus on mixing synthetic and conventional ATF is that it's ok, it's just that you won't get the full benefit of synthetic ATF as long as you've got it mixed with conventional. After three changes, I should be to 87.5% synthetic, if dropping the pan will drain out 50% of the fluid.
I thought I'd ask here, one last time, to see if the conclusion I've drawn (mixing is ok) from my own reading is in error. Let me know your thoughts. Thanks!
-Josh
Just change to all synthetic at once. After you drop the pan, put in about 8 quarts of the new synthetic. Remove a cooler line, and start it up. The old fluid will pump out. Put a few feet of hose on the line and put in a drain pan or bucket. After you've pumped out 4 or 5 quarts, about a minute and a half, shut it off. Put in another 4 quarts and start it up. Pump out some more till it changes color. Put everything back together and top off.
I know that sounds really easy to you, but I keep having visions of ATF spilling all over the place, not being able to get the cooler line reattached correctly, etc. I'm just thinking that it would be a lot easier to do the drop the pan and drain bit and then do another change in the near future. Is it going to do any *harm* to not change all the fluid?
I might try the pumping it out thing, I haven't completely decided against it--it just sounds much easier to drop the pan and drain and refill. If I had somebody to actually be there and walk me through the process, it would be a lot different, but I'd be totally flying blind--I don't have any buddies that are interested in helping me out with this. And I couldn't even tell you where the cooler line that I need to detach is.
Sorry, I didn't see the link you posted the first time. There's nothing wrong with mixing the two, you just won't get the full benefit of straight synthetic. It's not quite as scary as it sounds, but I'll be honest that if you don't know what the trans cooler lines look like, or where they are, you are probably not up to the job. I would suggest you find a shop that will do this for you. Don't let them talk you into a flush, tell them you want it done this way only.
Ideally, go to a shop, ask them how they do it. If they describe this procedure, use them. The money you will spend dropping the pan three or four times will offset the cost to have a shop do it.
Here's a question--when you pour fluid in the fill hole for the transmission, where does it go? Straight to the pan?
The reason I'm asking is, what happens if you're just pouring fluid in the fill hole with the pan off--is it just going to go straight down into your drainpan under the vehicle? That's what I'm assuming, but I thought I would doublecheck--this "flushing" type of procedure would not work by just leaving the pan off and filling the transmission fluid while the engine is running (and pumping the transmission fluid out of the torque converter). I'm guessing this would just burn out your transmission as it dumps the old fluid out without refilling it with new?
-Josh
Whoa.....
What ever you do, don't run the engine with the tranny pan off. I think you would be wise to get a shop to do this. Hopefully you can find one that will let you watch.
To answer your question, yes, the dipstick/fill tube dumps into the pan.
Let's talk about the location of the cooler lines. The more I can know about my truck, the better.
So here's where I think they are (light yellow lines highlighting what I think are the cooler lines):
Am I correct? And the one I would want to disconnect is the bottom one?
The top one seems like it would be easier to get too :-/
Also, people have talked about a clip that you remove to take them
off--mine appear to have nuts holding them in place.
Unless I am mistaken about these, and they aren't the lines I'd disconnect, or at least that's not where I disconnect them?
You can pull back on the plastic ring to reveal the clip that holds the line. The fitting will then look like this:
With a clip like this:
The plastic ring is to make sure the clip doesn't pop off
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
