G80 On The Front?
I've just done an axle oil change on my 2002 Suburban 1500 4x4 LT. I have the build sheet for it, it stated "Locking Rear Differential $252" however, when I drained the oil it was obvious the rear axle was a bog standard rear axle, which made me think the dealer had "Bumped" the original owner for $252, but when I dropped the skid pan, the front axle was I believe to be, according to the glove box info' a G80. My question is: Is this normal, to fit a locker/limited slip to the front axle?
Keep Rockin'
Gus in the UK.
PS. Great Site.
Keep Rockin'
Gus in the UK.
PS. Great Site. :cheers:
There is not a locking diff made for the front. You would not be able to steer it, and trying to would damage components.
If it is in the glove box you have a locker in the rear.
You can put a selectable locker in the front for wheeling. Such as an e-locker or air locker, but I doubt you have a G80 up front. My 03' Jeep TJ had an e-locker up front.
lockin front diff's are common and if you were to have one i would think a G80 would be better then a true locker [always in]
depends where you live and how much you offroad
the electric lockers are great because when your on a sideways ice or slippery snow sheet the rear and front will drift hard locked.
i would check the 4/4 forums and do some asking around because i know its been done many times over.
I looked in my 2002 Tahoe/Suburban owners’ manual to see what oils to use in the axles. For the Front Axle: It reads: SAE 80W-90 Axle oil (GM Part No 1052271). When I checked on the web what GM 1052271 oil is used for, this was the answer:
If you have a locking differential (G80), you need to use SAE 80W-90 GL5 Gear Lubricant, GM P/N 1052271. Do not use limited slip additive.
It would therefore appear that the 2002 4x4 Suburbans with a G80 limited/locking diff’ are all fitted to the front axles, why else does the manual instruction recommend the use of GM 1052271 in the front axle?
The Recommended oil for the rear axle is SAE 75W-90 synthetic (GM Part 12378261)
Which is for use in the normal standard axle.
I would still like to know if this is standard practise and was wondering if there is a GM Chevy Suburban department I could contact at GM?
I’d like to thank everybody for their comment. Cheers.
no, GM does not make a locking front diff!! dlstewart is right, i would completley screw up your handling if it locked on the road. it probably has a locking REAR diff.
anyway, go find some rocks and find out if you have a locking front diff, thats the only way to find out :jester:
As has been said, G80 only refers to the rear axle.
NO GM SUV's come with a locking or limited slip front differential. Its not an Regular Production Option.
fyi
LOCKING DIFFERENTIAL LUBRICANT (SERVICE INFORMATION)
SUBJECT: LOCKING DIFFERENTIAL (G80) LUBRICANT - (SERVICE INFORMATION)
VEHICLES AFFECTED: ALL LIGHT TRUCKS EQUIPPED WITH G80 REAR AXLE ALL YEARS
Some light duty trucks equipped with locking rear axles (G80) may exhibit rear axle chatter, especially when turning a corner from a stop.
This condition of alternate engagement and disengagement of clutches in differential assembly is usually caused by contaminated axle lubricant.
To correct this condition, drain and refill the rear axle. The use of any additive in locking rear axles (G80) is not recommended. Rear axle additives are designed for use in limited slip differentials which are normally installed in cars. All light duty trucks equipped with RPO G80 make use of a locking differential and the use of additives will delay the engagement of the locking mechanism and may decrease axle life.
This bulletin is being issued to inform dealers about the compatibility and usage of the new Fuel Efficient SAE 75W-90 Synthetic Axle Lubricant, GM P/N 12378261 (In Canada use P/N 10953455), with current axles, and with the non-synthetic axle lubricant, GM P/N 1052271 (In Canada use P/N 10950849), for the rear axles on the above light-duty trucks.
Testing has shown that the new synthetic lubricant will chemically attack the Room Temperature Vulcanizing (RTV) sealant. Use only the non-synthetic lubricant, P/N 1052271, in axles using RTV sealant (See 9.5 and 10.5 information below).
American Axle and Manufacturing (A.A.M.) has approved the use of the new Fuel Efficient SAE 75W-90 synthetic axle lubricant for rear axles with the following restrictions:
All 8.6 inch axles are compatible as originally built.
9.5 inch axles on vehicles built prior to mid-February 1998 are NOT compatible because RTV sealant is used on the cover pans. On vehicles built after mid-February 1998 and equipped with 9.5 inch rear axles, synthetic lubricant, P/N 12378261, can be used because the RTV was replaced with a gasket. Other mid-February changes to the 9.5 inch rear axles include a new cover pan and cover pan fasteners common to other axles.
Important
The new cover pan is not retro-fittable to the housing of 9.5 inch axles on vehicles built prior to mid-February 1998. A new retrofit kit is available that will enable the use of synthetic lubricant for vehicles built after mid-February, 1998.
All 10.5 inch axles prior to March 3, 1999 are compatible if the axle shaft hub seal (RTV) is replaced with P/N 327739 gasket when changing to synthetic lubricant.
As a product improvement, this new lubricant has been released into 1999 current production C/K vehicles built after the above VIN breakpoints (Except HD3500 models which use 75W-140 synthetic lubricant, P/N 12346140).
It is recommended that synthetic lubricant be used when changing rear axle lubricant for the following reasons:
Potential fuel economy
Lower operating temperature under severe usage conditions
Important
You do not need to wash/rinse any non-synthetic lubricant from the axle cavity when changing over to a synthetic lubricant. However, you should remove debris from the magnet and the bottom of the axle cavity whenever the axle fluid is changed.
On light-duty trucks equipped with locking differentials, do NOT use a limited-slip additive.
anyway, go find some rocks and find out if you have a locking front diff, thats the only way to find out :thumbs:
First off, let me thank you all for all your comments. You were all right the G80 locking diff’ is fitted to the rear. I’ll have to explain. When I performed the oil change I had jacked the whole vehicle off the ground, I then spun the rear passenger wheel and the drivers side wheel turned in the opposite direction, and therefore assumed the axle was a conventional one…which of course it is until one wheel spins 100 rpm faster than the other, you will have to excuse me for having a “senior moment”.
My drive has quite a slope, so yesterday I placed a couple of 8x4 plywood boards on the drive and greased them up and placed them in front of the passenger side rear wheel, and as you would expect the wheel on the grease started to loose traction and the drivers rear cut in as smooth as silk, pulled off the drive no problem.
I do hope this has not coursed an international incident or damaged Anglo-American relations. :wtf:
PS. Know what removes burnt tyre & grease marks off block paving? :lol:
Keep Rocking Gus
Keep Rocking Gus
I restored British roadsters for a number of years, (Triumphs) One of the jokes that went around was....
Do you know why the British drink warm beer???? They all have lucas refrigerators.......
Two time Vintage Triumph Register national best in show winner
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
