99 5.3 Into 79 El Camino
Hello people, I'm in the middle of a 5.3 into older non comp car swap. I need to know if I'm correct in assuming the engine will run correctly without the vss, the tranny wiring( I can't afford an electronic tranny yet ), body control module, electric brake control module,suspension control module, brake switch (until I put in electric tranny).
Also, I'm thinking that if I can find out the different resistances or better yet find out the resistance of the key that went with the computer I have, I could wire in a resistor to the proper ign wires to the computer. Any thoughts or help would be appreciated.
Should run fine w/o everything you listed, except the VSS...I am not sure on this one.
Only one way to find out right.
I'm not sure if key resistance will have anything to do with you starting this engine off the older ignition switch either. I believe that has to do with the Passlock, and that's a BCM program.
You will need the VSS for the PCM for vehicle speed data. You will need a custom tune to take care of all the other issues. The engine & PCM must have VSS,MAF,MAP,O2, CTS,RPM,oil psi and probably something i forgot to run and you will need a SES light and ALDL port to diagnose problems.
Oh yeah, this is an older 5.3L engine...it has the program on the ECU to run the trans too, I don't know how it will react w/o a trans.
I would wager that if it does run the best you will get is Limp mode.
I was doing some checking on this kind of idea and found this forum, www.LS1Tech.com and this posting that may be helpful. Good luck!
If your interested in a different route. I was watching powerblock this weekend where they turned a new style motor like the 5.3 from EFI to carburetor. They basically changed the intake and then changed the cam, with a gear on the end to run a distributor which goes into the new timing cover that comes with the kit. I'm not sure who made it but just to let you know that the option is out there.
I saw that episode. They should have done a dyno run with the stock cam. I am really interested in seeing if there was a power loss going to the carb? The swap seemed pretty straight forward. That was a 302 Ford distributor they used, Mallory oe something. Not sure how much that kit cost, but it is nice to see it does exist, as it really opens the door up for the hot rodders to say the least.
If you were going to use a carb, there's no point in using the 5.3, just stick with the early smallblock. The beauty of the LS engine lineup is the EFI itself.
Why not just use a carbureted 350? I'm not trying to be a dick or anything but what kind of benefits are you looking for with using this 5.3? It would be so much easier just to put an old small block in. But whatever you wanna do. Good Luck to ya. Id like to know how it turns out.
Well, everyone and their mother has a carbureted 350, and how many have a carbureted 5.3?? I say go for it.
would the suggestion of an LT-1 powerplant work here.....you could probably get a complete donor 9c1 for $500...and the performance stuff is abundant.
easily end up with fuel injection and 400 hp for relatively cheap.
    TopBo
    TopBo
  • Who's Online   5 Members, 0 Anonymous, 1,643 Guests (See full list)
