Look At This!
looks like a cool concept truck. 550 hp is kickin. i bet the rear fascia with exhaust cutouts won't make it to production, at least not as shown on this concept truck. i typically hate exhaust cutouts on trucks, but those look nice and clean.
found this part interesting:
According to GM design chief Ed Welburn and ZR2 designer Dave Ross, the subtle upgrades to truck's styling offer hints at the next Silverado facelift. They include a boxier grille, exaggerated hood and fenders, rear fascia with integrated exhaust pipes and a new tailgate with "Chevrolet" embossed in it.
Yes but there not street legal.
:lol: Why's that?
+1
And I have to say that truck looks amazing. I even like it better then what dodge has done with their duel exhaust on the new trucks.
The vehicles have to be EPA certified to be legal. All show or EXP vehicles the MFR's have build cannot even be titled. You will notice that Ford states the F-150 Raptor is not street legal.
:lol: Why's that?
Don't dig the fender flares. I would hate to see GM's version of this style in regards to the wheel opening.
I definitely like the powertrain. They probably put the 6L90 from the 3/4 tons in there with some modifications to hold all that power.
hate to tell you the raptor is fulley epa compliant and dot aproved . i've seen us take delivery of three of them .still come with a 3 , 36 waranty to covers everything
hate to tell you the raptor is fully epa compliant and dot approved . I've seen us take delivery of three of them .still come with a 3 , 36 warranty to covers everything
Yep saw one driving around already with license plates on it. :lol:
