Some Help Needed
I have a 2000 GMC Sierra with the 5.3. I have been looking into some options for putting and exhaust on it, and am getting mixed opinions on what i have been reading on other sites. So I was wondering if anyone could give me some opinions on what I should be looking for. I know I want to have it be a dual exhaust, and I want it to be a loud low sound, but i don't want it to have the annoying crackling sound on so many exhausts you hear. And help or information would be greatly appreciated.
Magnaflow
Single in, Dual out Cat back kit. That's your easiest option, and it sounds the best for loud, low and no drone/crackling. Plus its stainless and looks good as well.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 524 Guests (See full list)
