Fuel Leak
post-51136-1262453491_thumb.jpg fuel leak on 1997 z71. Temperature out side -30. Truck starts, runs, and drives normal but smell of gas. Reason for leak? How to stop leak? Location of leak?
That's the fuel pressure regulator with the vacuum hose attached to it. Have you observed fuel leaking while it's running? Any chance it's spraying/leaking where the FPR attaches? I'm not that familiar with your model years rail system. If the two lines above the FPR are leaking and they "plug-in" to the rail there are seals that need to be replaced
FPR shouldnt take more than 5 min to swap out. Even if its cold its an easy job.
Yes it does leak where the two hoses attach vertically in to the fuel rail tube. The first morning that it was noticed a sizable amount of fuel was on the snow. Now just as the picture shows. The pressure in the line does leave the smell linger in the air for some time.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
