Ford Takes Yet Another #1
P71_CrownVic
Numbers and statistics are largely useless without context. Edmunds.com took a first good step in going through NHTSA's data base and reporting the number of UA events reported per make, brand and vehicle. But what was obviously missing was the correlation to the number of cars on the road in relation to those numbers. We've taken the next (tedious) step, and the results are most interesting indeed. They're certainly not completely conclusive, but we're not finished yet. The full list of 95 cars follows, as well as our methodology, a stab at some analysis, and more questions to still be answered.
First, our methodology. Edmund's NHTSA data was for model year 2005 – 2010 cars, to date. Lacking easy complete sales data, I've taken the 2008 MY sales for these vehicles, and multiplied by five to arrive at a working number. If detailed sales numbers are to be found, I will update them. But I doubt it would change the numbers significantly.
Obviously, the cars that had lower numbers of events reported are going to be statistically less reliable. And unless we go back to the NHTSA and mine the original data, if that level is available, we don't know what type of UA event was reported. Was it a likely wrong pedal application, which typically happens at low speeds and often in parking lots (hopefully not near a cliff)? Did it come on after merging into a freeway? Having that level of detail would allow us to make further assumptions, especially if certain cars had higher incidents of a particular type of UA event.
The other thing is consider whether the given vehicle had brake override or not. On the one hand, it's interesting to note that no European brands were reported, and they pretty much all have brake override. But then so does Chrysler, and several of their cars, especially certain Jeep models, had fairly high rates of reported UA.
There are other factors to consider, like the demographics and use of the specific vehicles. I suspect strongly that the Lincoln TC, the Grand Marquis and the Crown Vic all have the same mechanical and electronic systems. Yet the TC came in #1, the Marquis #9, but the Crown Vic at #32. Is the high proportion of CV use in taxi and police service an issue here? And what are the TC and Marquis owners' median age?
So many questions and so few answers: Ford, which does not have brake override, had some models fairly high on the list, but the popular Fusion was very low with a rate of .005, and its sibling Milan with a .006. The fact that these virtually identical cars came in so closely gives support to these statistics being reasonably accurate. Other examples are GMC Sierra and Chevrolet Silverado at # 94 and #95. And the Malibu and similar G6 are at #84 and #88. But then when it gets down to such few reported events, randomness increasingly becomes a factor.
GM's low UA rate is undeniable: their highest car is the Cadillac DTS, at #40. It also has a notoriously high median age of its owners. The mechanically related Lucerne and Impala are not far apart, with the Lucerne being somewhat higher and undoubtedly having an older median age of its owners. I'm conjecturing here, but the numbers tend to bear it out.
Clearly, Toyota vehicles are skewing to the upper end of the range, although the Corolla/Matrix is down at #38. And the Yaris is very low on the list at #79. What exactly puts the Lexus ES 350 at such a high rate is certainly worth exploring, especially since it was involved in the two must publicized UA events. Its general mechanical similarity to the Camry is well known; without breaking out the types of events the ES 350/330 has been involved with, its difficult to say. But additional information would be indicative, since the Camry is not all that high on the list at #11. Are Lexus floor mats thicker and deeper than the Camry's? Are the electronics substantially different? Are Camrys imported from Japan involved at higher rates? ( all Lexus ES models are also imported).
The questions go on and on. I will continue the quest of turning up statistics that shed further light on this issue. And your comments , analysis and questions will be most appreciated and helpful. One thing: keep in mind that these are only those cars that had UA incidents reported to the NHTSA (actually, I removed a few out-of production cars from the list). Missing of course are all those cars with no reported incidents, including whole brands, like Hyundai, Kia, Mazda, Subaru, Volvo, and all the Europeans (except Saab). Did I miss someone significant? Full list follows:
The first GM vehicle is at #39 and the Silverado and Sierra are at 94 and 95!!
LINK-TTAC
maybe torque management is a good thing lol, GM i dont think even made the top ten
The highest GM on the list is #39, the GMC Envoy. Which is surprising to me, since I've owned multiple Envoys and Trailblazers, and worked on/driven probably well over a dozen others and I've never seen or heard of a single problem.
Of course now that I've said that, I'll probably go out in my Envoy Denali and die now :shakehead:
It's extremely rare...even for a Camry...despite what the media would have you believe.
The Camry has 5 complaints of UA for every 100K vehicles sold. It's really a non-issue.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
