The "What I did while GM-TC was down" Thread...
Zane
Me first...
I worked on getting GM-TC back online, slept very little, and ate way too much takeout. :rolleyes:
Sorry guys- we'll be posting a thread later explaining why the site has been down all week. Welcome back and thanks for bearing with us.
Me first...
Wohooo !! thanks for bringing us back !!!
I was actually doing some work on my truck and had to resort to another forum for help. Makes u realise how much better this one is! It's back woohoo but I see it's also back to the old template I guess the new one won't be here for awhile lol! so happy it's back up!
it's odd surfing through the forum cuz all the threads don't have a reply since may 1st! spooky! lol
Well... WELCOME BACK boys!
I bet that was a real hair puller... I know it would be if my sites were down.
It's BAAAAAAAAAACK!
I was starting to get major withdrawal over here!!
Good to see we didn't lose much (if any) data in the debacle... that was my biggest fear when I saw how long everything had been down.
I went cold turkey. I had to get on a substitute board. I'm glad I can get a fix of the real thing.
With all the he!!, :rolleyes: did you install the system upgrade or just get the system back up and running.
Just curious ?
Thanks for all the long days/nights. :lol:
i was forced to converse with people in real life by using my vocal chords instead of a keyboard...... it was scary..... please dont ever leave me again
lol honestly i think i got LESS work done at work... i have adhd or whatever its called because i need to have 10+ things going on to get anything done.
I actually got a few things done around the house, played a round of golf, installed a GMPP CAI on my truck, greased the slip yoke, waxed the truck, and built a phone system for my house. I can't handle that much at once, so I am glad the forum is back up :rolleyes:
Thanks for all the hard work to get the forum back on-line! I appreciate the efforts!
I did a Full Detail for Retail on Our Truck of Win and Awesome, and found the first bit of Dropped money on the Floorboard! the Win and Awesome Rating is back to August 3rd Levels!
any news on when SSS.com will be back up :sigh:
BTW...THANKS for all the hard work you all are doing.. :rolleyes::lol::lol:
:P
SilveradoSS.com just finished restoring a few minutes ago. :cry:
:seeya:
:P:sigh::cheers:
:seeya:
What I did while GM-TC was down.....
Drank heavily!! :lol:
Thanks for all the efforts to get us back on line....because I was almost out of booze!! :rolleyes:
What I did While GMTC was down.............
Lurked around on performancetrucks.net, and hit the refresh button every 15 min on the other tab with GMTC website address in it.
Yeah guys...your efforts, and sleeplessness is much appreciated.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 508 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
