Where Do You Buy Your Accessories?
Our truck "extras"
19 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I have been searching for accessories for our new Silverado, and wondered where most of the fellow members here on GM-T buy their "extras". Things like vent visors, mud flaps, nerf bars, floor mats, etc...
I have found that a local shop has prices that are very close (or even cheaper) than buying online.
If something was considerably cheaper I would order it, but if it is reasonably close, I am giving my money to the local shop.
Chris
Take a look at GMPartsdirect.com
I have spend almost 1k with them over the last 3 years and havent had a single issue. Its all OEM GM parts. Prices are way better than the stealerships around my area.
I find the lowest prices online and the local shop price matches it...
I still end up paying a little more (tax), but I am all about supporting the local guys
I made friends with the parts guy at the local dealer. He's a good guy and gives me trade cost on everything. Check out the dealer where you bought from, can't hurt to ask what they can do for you pricewise on some GM accessories.
Cabelas for floor mats, vent visors, bug deflector
gm dealer for nerf bars
mudflaps, came on my truck part of protection pkg.
I prefer to buy most things local when I can, even if costs a little more. No local stores in my area though for truck accessories so I buy on line. Usually I buy from well know vendors but have dabbled in Ebay from time to time.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
