2005 Tps Value
Ray2005Chevy
I have a 2005 5.3L Silverado 4 x 4 auto with horrible gas mileage - power is not that great either. I put my scan tool on the truck last week and drove around while observing some of the readings. The first thing I noticed that appears to be abnormal (to me) is the closed throttle TPS reading is not 0% - it is between (yes - it varies) 12% and 25%. The % calc load reading at idle is around 30% and goes above 90% with light acceleration. Cruising at 60 mph gives me a % calc load of around 50%. Are the values normal? Thanks.
Well here are my numbers, tps idle-0to.7%, calc. load idle-1to3%, 60 mph load-17%, light acceleration-35to65%. So your numbers look high to me.
Check engine light should be blazing with those numbers ....
Throttle angle above 12% can easily be caused by something as simple as throttle body carbon.
That's a 12 to 15 mpg vehicle on a good day with a light throttle and a tailwind.
Does this vehicle have Throttle Actuated Control. if so then i would say it is normal because the throttle plate is controling your idle. if it uses a throttle cable then the Idle Air Control solenoid to keep your vehicle at idle, and the throttle plate can be fully closed.
