Looking for a 4 hi (headlight) mod. Saw it somewhere...?
There is a kit I bought on eBay that when you turn your brights on it includes the fogs if that would be anything you'd be interested in, works damn good other than I wasn't too big on the scotch lock they sent so I soldered and heat shrank my connections.
900 series trucks are already 4 high
I know they do the high 4, the kit I'm talking about that I installed doesn't let the factory fog lights cancell out in high beam
  • 4 months later...
Anyone try adding an LED off-road light bar behind grille to make it hide away, but add the extra light? End goal for the vmax of mine is a zone 3" lift and wheels n tires but was considering a off road bar but want it hide it. Looking for mounting suggestions without cutting grille just let it shine throughout the mesh
I believe RIGID LEDS makes a kit to install the little square LEDS in the FOG LIGHT hole not what you want but gets you "closer"
40" light bar
40" light bar
That looks great, and pretty bad a$$ if I do say so myself. Where did you get the light bar
  • 8 months later...
Rigid Industries makes the fog light mount for ~$70-80: http://www.rigidindustries.com/mounting-options/40337
You basically get to choose two sets of the D-Series lights to go with it. The sets run around $200 each. I went with one set of the new DOT/SAE approved ones, and one set of white/spot offroad ones.
The light strips behind the grille I did just for fun haha. Cost about $30
The headlights are from spyder, and the bulbs in them are PIAA Xtreme white plus. $300 for the headlights, $100 for the bulbs.
I did all of the work myself so no labor cost :)
Just looked again. $101cdn for the mount, $253cdn for each D2 light. = much $$$$ lol Looks great though!
The D2 is more expensive than the Dually, but they're the same size. Both can fit with this kit. The main difference is the D2 contains 6 LED's per cube, and the Dually only 4. The beam patterns also differ. I went with the Dually.
can I ask why?
can I ask why?
The DOT/SAE approved fog light is only available in the Dually out of the 2. I really wanted legal ones tied into my stock fog switch. Then for the OffRoad only ones, it came down to cost.
I've actually ordered 2 more sets since, and I'm hoping to mount them in the next couple of weeks here. I'll post some pics when I do.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
