Best Motor Oil
A Shaffer's sales man is coming tomorrow to show how great their oil is. They have a bearing type machine that you apply pressure to to and try to stop the motor that spins it. He says their oil beats many of them hands down, including John Deere, Royal Purple, Amsoil, Mobile 1, and more. Anyone familiar with this test or have oils that I should try that my hold up. I never see Shaffer's come up on any of these oil debates. I run Mobile 1 because it's fully syn., and it's on the shelves around hear.
Paulie G
Schaeffer's oil is a good high quality product. You do not see much of it because it isn't offered in the general retail stores like all the other oils, you can find it at select automotive supply stores. You can do a search on their web site to find a retailer closest to you. It has been around a long time, starting in 1839.
red line, they have a test that uses the same machine to prove their oil
Paulie G
While this machine may have the wow factor going for it, it really has absolutely nothing to do with how the oil performs under any circumstance but cold start-up.
Take the demo with a grain of salt.
I have seen the same machine used for demonstrations over fifteen years ago. It was for a anti friction oil additive.A few heavy trucking company's used the additive for a couple of years with no significant differences. Later the friction additive company just faded away.
X2
DEWFPO
X2
DEWFPO
A big X3
That machine is called a "one arm bandit" and can be manipulated to show any result the tester wants. It proves nothing except the person using it to sell oil is a con man.
Here a demonstration if it
All BS tests aside I use Schaeffer's oil and will surely stand by it's quality. My uncle is a distributor so I get it easy and will always run it as long as I can get it.
Paulie G
This is a timken bearing pressure and friction machine. It in no way simulates how good the oil actually does in an engine. It only proves how good it can stand extreme pressure like found in a rear end. Tell him to put regular gear oil in it and it will do just as good as the oil will. There's no reason for that amount of pressure modifiers in motor oil and thus proves nothing in an actual engine.
After watching that, I'm switching to Head & Shoulders from now on for my engine! :rolleyes:
Why rag on the oil? Because a dumb salesman is using a stupid test to sell it? Guess this post was just passed over.
I don't think anyone "ragged" on the oil, just the "testing" method that many lubricant salesman rely on for demonstrative purposes. Nick stated that it is a good oil. I've heard good things about it as well. But I won't be switching to it. Based on real world sampling and testing, I'm satisfied with my choices right now
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
