Atv In Bed Or Trailer
Probably a stupid question :cheers: but what is easier on the engine to tow a 650 pound atv in the bed allowing the back end to sag or towing it in a in a trailer with a total weight of 1600 pounds. I figure in the bed but am unsure because with the ATV in the bed the back end drops a fair bit but in the enclosed trailer the back end stays as normal and does not sag.
Brandon :P
In the bed would burn less fuel. It take so much energy to move so much mass. A 1600 pound trailer would likely have 300-500 pounds worth of tounge weight. So I would be shocked if the quad squated the truck much more then the trailer would. 600#s setting mainly over the axle vs 4oo#s out in back of the bumber well behind the axle.
The ATV when in the tailer is at the back by the loading ramp and the tongue weight is only 340 pounds thats why I wasnt sure if it would cause less stress on the engine to tow it instead. I see where your coming from now. Thanks
Brandon
Brandon
this must be some heavy duty trailer.?? only 340??...thats alot. it should be typically no more than 10-12% of the total gvw of the trailer. I.E. 160-200lbs. Remember,...the trailer must be level when weighing. If you have the tongue directly on the scale,..it will say it weighs more due to the downforce of the load over the axle. (not knowing if you have some sort of tongue toolbox or something).
Sorry Im estimating the tongue weaght and I do have a tongue box with a spare tire, jack and jack stands in it. I have not used a scale to get the exact amount.
Brandon
hauling the quad in the bed would be most efficient... less overall weight that the truck has to get moving and keep moving plus no added drag from the extra set of tires on the trailer.
I usually put my quad in the bed and i do notice better fuel mileage over hauling it on either of my trailers.
Thought so, thats the answer i was looking for thanks
brandon :P
If you have a small light weight trailer like this. Then for me its been sort of a toss up. My truck drops down to about 14 mph either way. Just a little less hassle to manover without the trailer. The trailer in these pics is only about 500 pounds, and open so its not dragging a lot of wind with it, where an inclosed trailer you have to factor in additional weight and wind drag. I was thinking earlier that you probably had a single axle trailer so once the weight of the quad was inside it, I really think the tounge weight would be ever bit of that 300-400 pounds we were talking about. A twin axle trailer maybe a little less more in the 200-275 range, depending on the position on the quad to the axles on the trailer as to where the tounge weight would fall.
Do you have a grocery getter or a truck?
+100000000000000000000000000000000000000000000
You guys are funny im trying to take care of my truck and trying to save on gas :thumbs:
Depends, how well do you pull and push a trailer? Pushing is referring to backing..........
I am always game to drag a trailer............ Then again I am right at home pulling and pushing trailers..... Mirrors only....
Jbo
I consider myself good at pushing and pulling a trailer i do also use my mirrors but it took a bit of practice. :thumbs:
You never know I have seen tooo many bumpers with odd bend/fold marks...... Had to ask....
Jbo
Probably a stupid question :thumbs: but what is easier on the engine to tow a 650 pound atv in the bed allowing the back end to sag or towing it in a in a trailer with a total weight of 1600 pounds. I figure in the bed but am unsure because with the ATV in the bed the back end drops a fair bit but in the enclosed trailer the back end stays as normal and does not sag.
Brandon :thumbs:
You shouldn't have any sag with the ATV in the back. You should already have a 2" rake from the factory, putting the ATV in the back should level it out (did on my truck).
If the ATV is about the same height as the cab, you shouldn't even notice much for fuel economy loses either.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
