Can Gm Trucks Still Compete?
Blue2500CC
Is the GM Fullsize Truck in jeopardy? Can they compete with this?
Sorry for the poor cell picture, and missing part of the tow vehicle!
Would you have called the police due to the UNSAFE situation? I didn't, but keep wondering if I should have!
Chris
Only thing worse would have been if they had tried to tow it with a Tundra. :)
Hey now, it's 'best in it's class'
so much so the 11's had to have a tsb issued regarding certain models being off by 1,000lbs tow capacity i.e yoter inflated numbers :banghead:
you know whats really funny...i seen a Cadillac with a 5th mounted in the back....towing a 5th wheel camper. honest truth. i seen it in action as well....the picture is on my old phone i am moving next week if i come across it i will post. i almost got in an accident turning round to take a pic.
So what are the real Tundra's tow rating? I have always told people that I thought alot of the 1/2ton trucks(all of them) max tow ratings were on the high side, and the 3/4ton trucks were more on the safe side.
I traded in an 09 Tundra, 4x4 with the 5.7 motor, it had a 10,300 max tow rating.The truck was a mistake from the get go, as it fell apart, but the article the linked on the tundra forums was that some models were overstated by 250-500lbs and one model lost 1,000lbs from the number that was initially stated, essentially yoter was fluffing their numbers.
I would hope no one would put 10,000lbs behind a half ton, especially a toyota.
well someones gotta go it though, has to be least one idiot
There's plenty of those in the world. :)
    Clark_Elite
    Clark_Elite
  • Who's Online   5 Members, 0 Anonymous, 384 Guests (See full list)
    • Glad I found this post before posting a question. My ‘09 has been throwing those codes and P0442. I replaced the gas cap as it was trashed to begin with and the purge solenoid valve under the hood but still get the code every now and then. Dealership said I need to replace the vent lines as the previous owner use cheap fuel line that feels more like a balloon. They also said the charcoal canister and the “canister vent solenoid/service kit” so it relocates the filter up by the top of the transmission. Vent solenoid is cracked as the previous owner just let it hang loose. Too lazy to put it back on its bracket. If I put it on there the hose kinks and I thinks causes a whistle when I fill up.  Only issue is the parts guys can’t tell me which one I need as it shows two styles. One has a jointed section. Which should I use?  Thanks.  I apologize for hijacking the thread
    • UPDATE 3: Supposedly you need any cluster OTHER THAN a WT model cluster to have full steering wheel functionality. Went back to the part truck and removed the all terrain cluster, trim, and snipped as many wiring harnesses as possible to pull out the factory terminal leads if needed 😂 that poor donor truck…    As of right now I’m relying on Darth_Vader’s thread and YouTube videos. will update.
    • Was commenting on the engine labs article on lifter failure.
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
