Stability Control Sucks!
I just wanna fishtale in the winter. Bad enough I have traction controlled I have to shut off. I was spinning the tired today in the rain w the TC off and the brake was applied to one wheel. I need this disabled before winter.
You can turn Stabilitrak off,just keep pressing the button and it will show a message on the DIC "STABILITRAK OFF"
Yup, just keep holding the button after the DIC says "Traction off." A few seconds later it will say "Stabilitrac off." I think it still monitors a little bit though. Lets you fishtail and stuff, but it feels like power is a little limited, and it does feel like it hits the brakes a tiny bit, just not full out ABS like when its on. Could be wrong.
With that said, after 7500 miles the stock tires went from excellent traction to GARBAGE. Stabilitrac kept my truck out of the woods this past Thursday on a few occasions.
the day i purchased my truck, on the drive home from the dealership i turned traction control and stabilitrak off just so i knew how to do it. that was December of '08 and i haven't touched the button since. traction control and stabilitrak are my favorite features of these trucks. soooo nice for snowy/icy winters.
I assure you when your going down the road at 65mph and hit a patch of ice in a slight turn... the Stabilitrak does it's job!
As other mentioned, it can be turned off.
Funny thing is, mine spins the tires more on a wet road with the traction contorl ON, than it does with it off. Maybe they wired it backwards
Does the stabilitrac turn back on when the vehicle is restarted. After i read this i tried it in my truck and i got the "stabilitrac off" light (i didnt even know my truck had it). Then i held the button again and didnt get any message bout it being turned back on.
Yes,It turns back on when restarted,The operation is explained in the owners manual.
Is there any way to disable stabilitrac completely 100% via a tune or something? Nothing pisses me off worse then that damn stabilitrac/traction control.
  • 1 month later...
I like it on the road, but when I'm playing in the mud, I can't stand it. Gonna try turning it off and hitting my fav mud hole here in a while.
Tell us where you live so we can avoid the area when it snows :cheers: .
The 2011 HDs have a button to turn off the traction control.
When the salesman showed me the TC switch, I asked him why would I want to turn it off. He said, when you're offroad, & you don't want to lose your momentum in mud.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
