Diy Bed Lights
Since I bought my Silverado in June, I have partially debadged, changed out the ugly yellow bowtie in the grill with a chrome one, and installed Weather Tech mudflaps, a plasmaglow LED under tailgate light bar, EZ-Down tailgate piston, and a Lund Genesis roll-up tonneau cover.
With the tonneau on, it is quite dark in the bed at night time, so lights were needed. Instead of spending $100 on a kit, I decided to build my own.
Here's what I used:
I bought the LED strips on eBay HERE. It was about $25 including shipping for 2 strips 120 cm (about 4-foot) long. I attached them to the underside of the rails of the tonneau cover using 3M double sided tape. I popped out one of the plastic caps from the inside of the bed and drilled it for a toggle switch.
Some pics of the install.
I am really happy with the results. I think these are a lot brighter than the kits that only have small modules with a few LED's each - there are a total of 240 LED's in my bed.
Here's what it looks like at night all lit up.
Here's what I used:
very nice. how long you have had them installed??? only concern is long term durability
***very nice. how long you have had them installed??? only concern is long term durability***
I've had them in about a month now; I'll see how they hold up long term. I kind of wondered myself given the price. They seem to be really well sealed and all LED's light up.
The durability of my wiring I have no concern for, as all connections are sealed and all wires are in loom and zip tied in place. I suppose I can yank the LED's and hook up my wiring to some other lights if I have a problem.
Power comes from a ring tongue terminal I attached to the + side of the battery, with an in-line 10 AMP fuse. With the low current draw of the LED's, I didn't feel the need for a relay.
I grounded at the rear under the bed using an existing hole - I'd post a pic, but I'm not sure I could get a good one given the location.
Me Likey! Under my hard cover it's gets pretty dark as well...this could be just the ticket! What about drawing power from the trailer-light connection? Is any of that always hot?
Good idea. Yes, pin E with the red wire should be connected to battery voltage.
- Gabbypig
Yeah, Mitch's project was the original inspiration for my project. Thanks, Mason for posting the link.
