Afm Pre 2007?
Am I correct in saying that no Vortec engine had AFM pre 2007??
Yep...don't quote me but pretty sure...you are 100% true there. It wasn't available on the GMT-800 platform and started with the GMT-900.
That would be correct for trucks only. GM started using AFM earlier on some cars. For example, a 2006 model Impala SS with a 5.3 V8 had the AFM system.
Nope,The 5.3 (RPO code LH6) in the Trailblazer/Envoy/Ranier's had AFM starting in '05,It was called displacement on demand or "DOD"
Earlier year 5.3's (RPO code LM4) in '03-'04 did not have DOD,This is also the same 5.3 that was in the SSR's for '03-'04.
Thanks for the clarification. So any Sierra 1500 prior to 07 will not have AFM?
Ya'll respond so quick, working and posting are we?? :mad:
Didn't the Northstar engines have that DOD or something similar?
Nope.
Correct,No pickup truck prior to the '07 GMT900's had AFM/DOD,Just some of the mid-size SUV's.
Just to clarify, Silverados & Sierras did come with AFM in 2006. They were sold as GMT-900 2007 model year trucks.
Yeah,I said that already :mad:
Thats something I really liked about my 2006 Silverado LT. The 5.3l engine had no AFM, that was great. Fulltime V8 is great.
