275 / 60 R 20 On Stock Rims?
gsx2004
Looking into ordering the tires today, wondering if Cooper Zeon LTZ 275 60 R20's will fit on stock 20" rims with a RC levelling kit?
they fit on the rims.. doubt you can tuck them under the fenders without a lift..
the outer diameter of the OEM 275/55 r20s is 31.9 inches..
the outer diameter of the 275/60 r20 is 33.00
with the 2 inch leveling kit is it said that a 33" tire is the largest you can go.. so doing the math.. with the leveling kit they should fit, but you might experience rubbing in reverse against the front plastic inner fender covers.. so you may need to trim a tad..
and just so you know (and if you already do ignore this)
275 is the width of the tire in millimeters
60 is height aspect ratio, so 60% of 275 = 165mm
and 20 of course is the rim size..
a lot of people think the 45/55/60/75 etc is a set size.. it isn't, it is the % of the width.. so a 245/60 R20 would be more narrow, but the nearly (only .3 difference) the same overall diameter and sidewall size of the oem 275/55 R20
Thanks a bunch for the info, i am new to this so this is definitely a learning curve for me.
What size would you recommend going with a 2" level and cooper zeon ltz's?
I would think you could run those with no issues. Coopers tend to run a little on the small side anyway. But you have 2" of additional clearance up front and you are talking about a tire that is 1" taller than stock.
Yes, they'll fit fine and look good.
i had 275 65 20 on 20x8 wheels and the tires looked small
agreed, I prefer a small wheel size (17" or 18") with more sidewall.. 266/75 R17's are what I am looking at, they are the exact same overall diameter of the 275/55 R20s, but much meatier sidewalls..
if mine was a 2WD and I wanted to dump it, then yes 20's or 22's but 4WD with a lift, 17's max 18's
hey did you pull the trigger on the 60's yet? if so please post pics. i just bought some fatory 20s and am choosing tires also. was considering the yoko parada? ranked hi on tire tack withthe 55 size. i am going to keep my 18 all terrains in the garage for fun trips but for daily driving these 20's should be quieter and handle better on road.
I put them on last week along with my RC level, so far no rubbing at all. I will post pictures tomorrow.
Why tomorrow?!?!?!?!
I am being forced to go to a play tonight with the girlfriend so i will be home late, and if the stars align the last thing i will want to do when we get home is take pictures of my tires :(
your stars better allign for having to sit through a play
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • My centre console USB ports haven’t been working and the one in the glovebox is starting to act up. When I plug my phone into the cord the radio will go black and stop playing, and the CarPlay is inconsistent.   I checked the fuses and they were fine. I changed the USB port out and still nothing. Hoping for some advice on what I should be looking at.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
