Greasy Fingerprints
I bought a used 2007 GMC and it is in great shape. 40k miles, paint looks good (or so I thought) and no dings. I looked the truck over really good before I bought it and didn't notice anything. I get it home and start to wash the truck and notice what look like greasy finger prints on the hood. It looks like someone chainged the oil and then touched the hood. But you can only see them at a certain angle. How can I get these out? I don't feel to comfortable about taking a buffer to my paint. Would regular waxing and/or clay bar take these out? I'll try to get a picture up soon.
Clay is used to remove bonded contaminants. After you wash your vehicle and feel your paint and it has a rough feeling to it rather then being smooth thats where the clay would come in. You could definitely try a clay bar with the lube then if that does not help the situation try using some Meguiars ScratchX with a foam pad and work that it real good over the area in question and check your results. It may take 2-4 applications since its a mild paint cleaner. Then follow up with your choice of wax..
EDIT: A pic would really help.....
Yea, I'm gonna try to get a pic up as soon as I can. I get home after practice and it's dark so a pic prolly won't come until tomorrow. But I know for a fact it's finger prints. I just don't know how they got there or what substance made them.
if it is just oily finger prints, than wash the area down good with a moderate amount of Dawn dish soap. it will take the oil off, and it will take the wax off also, so after cleaning the area needs to be re waxed.. i know people who use Dawn as a cleaner/wash prior to clay baring..
good luck
If it is oil, then you don't need Scratch X. Just use a good dish detergent and wax the truck afterward.
I have seen plenty of guys do more than they need and they get themselves into trouble especially with a diminishing abrasive like Scratch X.
Try Dawn and see if it works.
    • Hi, New here.  2026 Denali HD.  Just purchased 7/2/26. I am having the same issue.  I just traded in my 2024 AT4, and the truck connected to bluetooth and Android Auto Immediately!  Now, with the new HD, it connects when it wants to, which is usually not at all.  I have to use the usb-c cable to get it to connect.  Bluetooth won't even connect without the AA. Now after saying all that, I'll take a 20 min drive with the phone plugged in.  Stop at a store, restaurant, etc....  Get back in my truck and DO NOT plug the phone in.  The truck then decides at this point, lets connect BT & AA and work perfectly, ie how it should.   I have deleted (forget phone) the phone multiple times.  I guess I'll just get used to plugging it in every time. even though I don't think its good for the phone battery to have it on charge after it hits 100%. I have searched all over.  No one else seemed to be having this issue, until I read this thread today.   thanks for reading.
    • I have an issue with my ignition hanging and I have to tilt the steering wheel to get in the off position. I have used a great key lock spray and it doesn't help resolve the issue. Is this an ignition assembly issue or something else. If anyone has a past experience with this please advise.   Thanks  Heath
    • This is a terrible GM warranty experience, two months waiting for a covered engine swap with no loaner or timeline is not allowed under GM’s courtesy transport policy.Escalate straight past regular support to a GM executive case manager, document every closed service ticket and dealer repair paperwork. File a complaint with NHTSA to force faster action, and ask for daily rental reimbursement while your truck is down. If it’s been out of service over 30 days, your state lemon law may let you pursue a full vehicle buyback.
    • 198°F isn't unusually hot for an 8L90, so I don't think temperature alone caused the issue. Since everything returned to normal after the truck sat for several days, I'd be looking at an intermittent electronic or hydraulic control problem before assuming the transmission itself has failed. The first thing I'd do is scan the Transmission Control Module (TCM), not just the ECM. GM transmissions can store manufacturer-specific or history codes that won't trigger a check engine light. I'd check: TCM history and pending DTCs Commanded vs. actual gear Line pressure Shift solenoid status Torque converter clutch (TCC) slip Transmission fluid temperature If it happens again, try to capture the data before cycling the ignition, since some intermittent faults disappear after a restart. A professional scan tool that supports full GM transmission diagnostics makes this much easier. For example, the Foxwell NT809BT can access the TCM, read manufacturer-specific transmission codes, and display live transmission data that's not available on a basic OBD-II reader: https://www.foxwelldiag.com/products/foxwell-nt809bt Hopefully it's just an intermittent control issue, but I'd definitely pull the TCM data before replacing any parts.
    • Sorry, I accidentally posted in the wrong language. I'll repost it in English.
