09lowessilverado's Cross Country Adventure!
truckofwinandawesome
well, we're going to California for Christmas to see some family, and We Pointed the Truck of Win and Awesome in a Westerly Direction, and 750 Miles and 10 Hours Later, we stopped for the Night in Elk City, OK. (Wingnut, Don't be suprised if you saw an Imperial Blue Metallic RCSB Silverado with TN Plates whiz by on I-40, That was us.) hopefully we will hit Albuquerque by tomorrow, and Bakersfield by Sunday.
You could at leasted honked the horn when you blew thru AR. But I would not stop here unless you want to "glow" the plant here does that to some people. :thumbs:
we actually Stopped Twice in Arkansas; Once at the Rest Stop just inside the Border, and Once in Elma to Refuel and for a Driver Change. and when we stopped in Elma, We turned on our Silverado Magnet! :lol: oh, and there's this nice little Restaurant in Calumet, OK where we stopped for dinner last night, the Pulled Pork Sandwich I had was REALLY Good! and then we Turned the Silverado Magnet back on there too! :bs:
here is a head's up...check the weather at Flagstaff AZ. it's known to have snow there this time of year. we have a large storm conning thru now, raining on and off for 2 days. if Flagstaff is clear, your good to go all the way down the "HILL" drop about 3000 ft. in about 10 miles.. :thumbs: the rest is OK. HW-58 going to Bakersfield can get snow, but as of now it's just rain...
enjoy your trip..
enjoy your trip..
Yep, I actually Drove THROUGH Flagstaff with VERY LOW Visibility. We've turned in at Williams, AZ where they have the Grand Canyon RR Its a Pretty town. To describe the Visibility, I'm going to Quote The two NASCAR Drivers from the First Cannonball Run Movie: "I Can't See S(*#&!" So we Hit Bakersfield at an Estimated time of Noon Central Tomorrow. so to any Residents of Arizona here on GM-Trucks.com, if you see an Imperial Blue Metallic RCSB Silverado with TN Plates, its us, Just passin' through!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
