Hello everyone, new to the board but in need of some advice. Last night, I changed out the pass rear shock that was leaking on my wife's '08 Yukon 2WD SLT (no upgraded suspension package). I only had time for 1 and the install went on without a hitch. When I turned on the truck, the ABS light is on, Stabilitrak "needs service" and tractioncontrol is off and needs service. I replaced "dummy" factory shocks with Monroes. There were no electronic connections of any kind and only 2 bolts for the entire install. What the heck happened along the way?
I am thinking that since I only changed 1 the ride level could be off and that would throw the stabilitrak, but the ABS makes no sense to me. Any help is GREATLY appreciated.
I don't think any part of the leveling would have caused the warning lights. I think its more probable, that there is a sensor that is disconnected dealing with ABS.
Shocks wouldn't of caused that issue, I think its a coincident. Have you tried disconnecting the neg side of the battery to reset the ECM?
So the truck has rear leveling suspension and/or electronic suspension control?? Either way, that wouldn't net you a service STABILITY or TRACTION light unless you damaged the wiring going to the rear wheel speed sensor that is in the axle tube near the brake rotor. If it DOES have leveling or electronic suspension, you'd have a service SUSPENSION system message and yes, that could be easily caused by replacing the shock. Need more info.
Thanks for the help so far guys. I did not disconnect anything other than the shock itself other than the plastic wheel well cover. I didn't even remove the tire. There were 2 sets of wires that laid across the top of the frame where the upper bolt is but I do not believe that I damaged those at all. The truck has 45K on it and has never had warning lights before. It made no sense to me. One other idea I had was RF sensors. I know there are a lot of components (in various objects) that have RF sensors and I was thinking that if the factory shocks had these that could throw the warnings. Other than that, I'll disconnect the battery and go from there.
my guess would be they're unrelated, unless you accidentally knocked one of the wires loose.
For $hits and giggles, put the old shocks in and see what happens.....but I'm 99% sure it has nothing to do with shocks at this point
Just wanted to say thanks to everyone who answered, its refreshing to hit up a new board and get pretty good feedback so quickly. I'll post what I find out.
Have you tried driving it? Is the anti-lock doing anything goofy?
Before taking the shocks on and off again-I'd recommend these "shot in the dark" attempts first-
1. Disconnect battery to allow ECM to reset
2. Take THAT wheel off, and see if any wires are loose or disconnected
3. Get the code read
Hearing that you had wheel well liners you pulled and replaced, is making me more comfortable in guessing that you bumped some connection for the ABS, where it connects right by the wheel.
Edited by Metro12
I drove it last night but it was too late to take it to Autozone for them to read the codes. It drove fine, brakes work as usual. Only real difference was the feel of having a functional shock. As far as ABS wiring goes, are they just standard plugs that terminate at the wheels? ABS was what made me nervous and I'm not super sure what I'm looking for other than damaged wiring. Thanks.
I had those same lights come on in my truck a while back and it ended up being a wheel speed sensor that was bad. That would be my guess, and that it is unrelated to your changing the shocks.
If it was a vehicle speed sensor, you would more then likely get a pulsation and delay in the brakes, the last 10ft before stopping. It would feel like you were stopping on ice. (When a VSS is bad, faulty, or not reading correctly, the ABS thinks the wheel is spinning at a different speed when braking, like when on ice and one wheel may lock and the others spin-which triggers your ABS to kick in.)
I'd take the wheel off, and just follow all the wires to connectors, and make sure they are all seated properly.
Edited by Metro12
should be delphi-style connectors clipped into the framerails above the axle... they run down from the frame to the axle, clip to the tube then run into the back of the brake assembly...just look and make sure the connectors are seated properly at the frame.
  • 3 months later...
Any update on what the root cause of this issue was. I have the exact same problem. Changed the rear shocks and got stabilitrack/ABS message when I started the vehicle. There doesn't seem to be anything special about the shocks unless there is some RF sensor installed in the OEM shocks.
+1
Either wiring to the sensor or sensor. Not related to the shock change unless the wiring you moved was speed sensor wires and they got messed up or maybe were partly damaged already and moving them 'finished the damage'.
If it throws the 'service' warnings, the ABS is disabled, so you won't feel the pulsation mentioned by Metro12 at low speeds.
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
