2010 Silverado 5.3 Oil Drain Plug
I am going to change the oil on my 2010 Silverado Z71 Saturday for the 1st time.
It has the aluminum 5.3 engine. I have a couple of questions.
1.Does anyone have any pictures showing the oil plug location ?
2. What is the torque spec on the oil plug ? Since it's an aluminum oil pan, I would rather use a torque wrench to make sure that I don't overtighten the plug.
3. Is necessary to use anti-seize on the oil drain plug ?
Thanks for any help and suggestions !
  • Replies 32
1. bottom passenger side of oil pan. 15mm wrench
2. just tighten with a wrench. you will feel the rubber seal bottom out, then just give it a fraction more. It is not likely to loosen so no need to get carried away.
3. no anti sieze necessary. there will be enough oil left in the valley of the threads.
I would also add when you take the plug out, be ready for the oil to shoot out a long ways.
Amen to this...It shoots almost over to the tire and then slowly gets back to the plug hole
Yes, it almost shoots all of the way to the tire! I learned my lesson.
yes, it is defanitally a surprise the first time you pull the plug. have fun with that haha. by the way, this is my first post on this forum :thumbs:
I have a small foot-pounds torque wrench, I use it to put my plug back on, it wastes no extra time to use, and that way I know its done right.
NO to the never-sieze
anyone know the thread pitch on the drain plug so when I change mine for the first time I can install one of these:
http://www.quickoildrainvalve.com/
I like that idea, its something I see on the D-10 Caterpillars at my work, but that being said they have pipe plugs on the end as well incase it fails, where these it does not look like they do. If they are not capped off as well, my advice would be to pass.
Here's a pic of where it's located:
I've also been thinking of getting one of those Fumoto drain valves (was leaning towards the one with the nipple for a drain hose to be attached to it). The F-107 and the F-107N (has the nipple) should be the correct part number for our engines. If you're worried about it the Fumoto site suggests getting a hose clip to secure around the release lever for added security. You could even maybe use a small hose clamp that'd require you to unscrew it first before activating the lever. But since, on these 5.3L engines at least, the plug exits to the side like that I wouldn't think there's much of a risk.
I'd also like to try one of these oil filter drain tools as well to puncture and drain most of the oil from the filter before removing it.
I figure if both those products work as advertised they could take most of the mess out of my oil changes.
Never liked any of those things that supposedly make the oil changes "easier". Every one of those easy drain valves flow much less so the drain takes longer and with a vertical oil filter the mess is minimal. Then again I spent like 3 years in a dealership so I probably did more oil changes in a month back then than most folks do in their entire life. :thumbs:
Glad I stumbled accross this thread. I would have made a mess. Maybe I'll get a bigger oil catch container. I'm used to the distance of the gmt800's that squirt rearward but sounds like these go quite a bit further.
Access is very limited to the oil filter. Not sure there is enough room to use the filter drain on these trucks.
They squirt out the same as the gmt800's. It is just to the side now v/s to the rear. I used to let it squirt into a funnel over my drain pan until I mastered the art of proper pan location. I usually put the pan where I think it will hit and slide it about 8" farther. Works every time. :P
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
