Removing Air Dam....
Hey guys,
I was recently reading in my manual and it states that when you remove the air dam it might cause the engine to overheat because of the missing airflow that is provided by the air dam. :puke:
So on one hand they suggest to remove it for offroading, on the other hand GM says one might get engine temp problems...so wtf?? :)
Has anyone experienced any issues after removing the air dam??
Thx
The airdam is for airflow. It creates a negative pressure right behind it that pulls the air down so it flows through front of truck, through radiator and then down and out.
If you are not pulling load, etc, you will probably never overheat with it removed, but if you take it off and are pulling a grade with a travel trailer on a hot day, you will certainly run much hotter than if you had it on.
There are many discussions on this for the year(s) that the duramax had over heating problems due to under hood temps. Having a proper air dam was part of the solution.
All I can say is that my air dam is about as flimsy as it can possibly be. It shakes if you breathe on it. I removed it and reinstalled it when I was installing fog lights. Looks like it belongs on a go cart, not a full size pickup.
If this is an issue than why do the 07-10 HD trucks, which essentially have the same bumper design as the 1/2 tons not have an airdam on the bottom?
The same goes for the gmt-400 platform, both trucks had the same front end same bumper, but only the 1/2 tons had airdams, where the 2500 and 3500 did not include one.
I took mine off right after getting the truck and have not had any issues.
That being said, I am probably going to briefly put it back on again this summer. I'll be driving 1300 miles non-stop (other than gas and bathroom breaks) up to Canada with the boat in tow for a week of fishing, and then driving back non-stop again afterwards. I figure, even if it only gives a slight improvement in gas mileage and/or cooling, that'll be the time to use it given the long sustained drive with the boat trailer and the warm summer temperatures.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
