What Shocks Do You Have?
I need some new shocks, and want to see what all of your reviews are.
I do moderate to light hauling in the truck, and the occasional trailer.
Empty driving is usually 70/30 highway/city. I do also work construction, so I encounter the occasional sloppy jobsite, and I like to "lightly" play off road occasionally as well.
What would be the best set for me? I know the new GMC's have Rancho's, and the Chevy's don't. I will say that I love the ride quality differences from my GMC to another Chevy.
James
I haven't changed shocks on the truck yet but based on my experience with my other cars. Bilstein is what the truck will get without any second thought. Buy them from someplace like Tirerack and they are barely any more than a "premium" parts store shock like a highend Monroe.
any ideas as to why the 5100s for my silverado it says i need a two inch lift on the front for my truck, but the ones that come up for your truck dont require the two inches? they are the same part number? and would a torision bar crank be the same as having 2 inches of lift on the front?
part number 24-186643
2001 sierra 1500 5.3 4x4:
46mm Monotube Shock Absorber
Part Number: 24-186643
MSRP: $145.00
Old Part Number: F4-BE5-C153-H0
Setting: 5100 Series
Bilstein 5100 Series Shock Absorbers are high gas pressure monotube shocks designed specifically for lifted pickups, SUVs and Jeeps. The shocks feature a 46mm digressive piston with self-adjusting deflective disc valving. They offer super damping ability that makes them ideal for heavy hauling or occasional off-road use, while maintaining an exceptional street ride. (zinc-plated steel body, Triple-C-Technology® coating )
Descriptor: Front Lifted Height: 0-2in
Drive Type: 4WD
Position: Front
Quantity Per Vehicle: 2
Spring Type: F: Torsion Bar / R: Leaf
2005 silverado 1500 4x4:
MSRP: $145.00
Descriptor: Front Lifted Height: 2in
Drive Type: 4WD
Position: Front
EDIT: didnt realize that you have a 2500- and go figure the shocks for yours and a 2005 silvy 2500 are exactly the same.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
