2" Level Vs 2.5"
So i'm torn between a 2" and 2.5" level for my sierra. I'm looking at the rc 2" level and the Topgunz 2.5" level kit. Ive been reading around here and it seems like a 2.5" may be a a little to much stress on the ball joints. Anyone have any input on the 2.5" or experience with it? Thanks.
I've had both (daystar 2" and currently CCM 2.5"). No issues with either one. I like the CCM better, and I could tell a difference in height vs. When I had the 2" leveling kit.
I looked at the ccm as well but im not to into having to cut my strut bolts. How are your angles with the 2.5?
2.5" is the max for sure, and will obviously produce harsher angles, but I don't think you will notice an increased amount of wear as directly compared to the 2" kit. The 2" kit is a little easier on the front end and much easier to install, but will likely not achieve a truely level stance. It's a toss up really based on what you like. I personally like the level stance achieved by the 2.5" kit, but prefer the angles and ease of installation of the 2" kit.
I agree, and I didn't install it. The shop threw it in there when they were taking off that piece of shit RC 3" lift. Blackout 07 is right on the perfectly level stance and I don't think it will wear on the front end any more than a 2" will. I have had to replace 1 axle, but it was because one of the outer boots tore close to the band attaching it to the axle or I hit something. It was unrelated to having a leveling kit. I've had a leveling kit (either one) for almost 35,000 miles with no issues.
Well sounds like it shouldn't be to bad then. I'm gonna go with the topgunz 2.5" unless someone can steer me towards a better 2.5" kit. Ill be putting 3" blocks in back but ill just get them from zone.
Like I said, I don't have any experience installing them, buti think CCM is the favorite of the two by most people. Either way, they both do the same thing essentially, so I would just to with what's cheaper. I have the same setup just with the zone 1.5" added on top of it. You will like it a lot. And not to be too picky, but if I had it to do over again (didn't bother me enough to want to change it), but the 3" block is a little too much rake for me on some days. I almost wish I would have went with a 2.5" or 2.25" block in the rear. Again, that is just me being picky.
I like a little bit of rake personally. I saw a couple pics of your truck and others to with a 3" block and i really like it.
  • 1 month later...
Just to note I've had a 2.5" level kit on my 08 Sierra and have had no problems with it. It has been on the truck for about 75,000 miles. It is a 4x4 truck.
I ended up going with the Top gunz 2.5 and im very pleased with it. The angles aren't near as bad as i thought they'd be and the truck looks great.
we need pics!!
I know I know, i gotta find myself a nice flat level surface somewhere that i can take pics. Ill start a new thread when i get some pics.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
