Fun at Papa's with my daughter. I tease him that we have "his and her" trucks, but the little thing has the 5.3 and goes like hell. and the bike....oh well, one day!!!
oh dam.....all that work and i guess the images didn't transform. have to try to add it to the album section. cheers!
That's a hell of a good pic!
Sent from my SAMSUNG-SGH-I927 using Tapatalk 2
  • 5 weeks later...
My 04 Sierra.
Leveled/added 1" block
LQ9 6.0/Dyno tuned to 325 HP at the wheels
Silverado SS wheels
SLT interior conversion
MBRP cat back
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Good to see you got it done. So how do you like it compared to the 4.8? Better be easy on the throttle tires brake loose quick.
Sent from my iPhone4S
using Tapatalk
Oh I know. Its been raining here. Accelerates a little quicker. Can definitely feel the torque difference
Another but with the old 4.8 and my DC Power Engineering 300 amp alternator. Its been taken off because it was wired for the newer trucks with the 2 wire harness and I have the 3 wire.
Edited by chawkins6789
Here is my 2012 Tahoe LT w/ luxury package, 4x4. It is Greystone metallic. I have added mud flaps, bug shield, window vent visors, and HID's for the lights. I have also upgraded the tired to BFG Rugged Terrains.
My truck and my toys!
2007 Z71 5.3
2008 zx-10r with WAY to many mods to list, lets just say I can spin the tire in 3rd gear doing 70MPH, dont ask me how I know!
2010 KTM 690 SMC, by FAR the most fun toy I have!!
Edited by h20-50
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
